ZD-N Plus Wireless Controller Rumble Motor Replacement
  1. ZD-N Plus Wireless Controller Rumble Motor Replacement, Back Panel: step 1, image 1 of 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
    Ask FixBot
  2. ZD-N Plus Wireless Controller Rumble Motor Replacement: step 2, image 1 of 2 ZD-N Plus Wireless Controller Rumble Motor Replacement: step 2, image 2 of 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
    Ask FixBot
  3. ZD-N Plus Wireless Controller Rumble Motor Replacement, Battery: step 3, image 1 of 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
    Ask FixBot
  4. ZD-N Plus Wireless Controller Rumble Motor Replacement: step 4, image 1 of 2 ZD-N Plus Wireless Controller Rumble Motor Replacement: step 4, image 2 of 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
    Ask FixBot
  5. ZD-N Plus Wireless Controller Rumble Motor Replacement: step 5, image 1 of 2 ZD-N Plus Wireless Controller Rumble Motor Replacement: step 5, image 2 of 2
    • Remove the battery from the controller.
    Ask FixBot
  6. ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: step 6, image 1 of 2 ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: step 6, image 2 of 2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 647
