ZD-N Plus Wireless Controller Battery Replacement
    1. ZD-N Plus Wireless Controller Battery Replacement, Back Panel: step 1, image 1 of 1
      • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
      Ask FixBot
    2. ZD-N Plus Wireless Controller Battery Replacement: step 2, image 1 of 2 ZD-N Plus Wireless Controller Battery Replacement: step 2, image 2 of 2
      • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
      Ask FixBot
    1. ZD-N Plus Wireless Controller Battery Replacement, Battery: step 3, image 1 of 1
      • Use an opening tool to pry the battery from its original position.
      • The battery is glued on, so this may take some effort.
      Ask FixBot
    2. ZD-N Plus Wireless Controller Battery Replacement: step 4, image 1 of 2 ZD-N Plus Wireless Controller Battery Replacement: step 4, image 2 of 2
      • Use an opening tool to pry the connector away from the two metallic prongs.
      • The parts are built to stay together, so this may take some effort.
      • Be careful to not warp the prongs in the process.
      Ask FixBot
    3. ZD-N Plus Wireless Controller Battery Replacement: step 5, image 1 of 2 ZD-N Plus Wireless Controller Battery Replacement: step 5, image 2 of 2
      • Remove the battery from the controller.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 40
All Time: 888
