ZCWA BR151 Wheel Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
16
Past 30 Days:
95
All Time:
1,319
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you need to install or replace new wheels in your ZCWA BR151 vacuum, access the wheels from the underside of the device by using this guide. There could be a buildup of dust or other foreign objects in the wheel chambers, causing a potential blockage. A complete replacement may not be necessary. The wheels are moderately accessible, but there are several pieces to remove for full access. You will not need to do any difficult steps, but be advised that there are several pieces to keep track of. Be cautious when separating the top of the device from the bottom of the device; the two components are held together by wiring. Before starting the guide, be sure to power off the device and drain any water from the device's water tank.
Tools
    1. ZCWA BR151 Wheel Replacement, Water Tank: step 1, image 1 of 1
      • Turn off the device.
      Ask FixBot
    2. ZCWA BR151 Wheel Replacement: step 2, image 1 of 2 ZCWA BR151 Wheel Replacement: step 2, image 2 of 2
      • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
      • Pull it out.
      Ask FixBot
    1. ZCWA BR151 Wheel Replacement, Wheel: step 3, image 1 of 2 ZCWA BR151 Wheel Replacement, Wheel: step 3, image 2 of 2
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      Ask FixBot
    2. ZCWA BR151 Wheel Replacement: step 4, image 1 of 1
      • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
      • Remove the bumper guards by lifting them.
      Ask FixBot
    3. ZCWA BR151 Wheel Replacement: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
      Ask FixBot
    4. ZCWA BR151 Wheel Replacement: step 6, image 1 of 1
      • Use a Phillips #1 screwdriver to remove three 8 mm screws from the wheel plate.
      Ask FixBot
    5. ZCWA BR151 Wheel Replacement: step 7, image 1 of 2 ZCWA BR151 Wheel Replacement: step 7, image 2 of 2
      • Carefully lift the bottom panel off of the top.
      • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
      • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
      Ask FixBot
    6. ZCWA BR151 Wheel Replacement: step 8, image 1 of 1
      • Though optional, we recommend separating the top and bottom panels for easy access to the wheels.
      • Pinch the wire bracket that is on the top panel while pulling the bracket away.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      Ask FixBot
    7. ZCWA BR151 Wheel Replacement: step 9, image 1 of 3 ZCWA BR151 Wheel Replacement: step 9, image 2 of 3 ZCWA BR151 Wheel Replacement: step 9, image 3 of 3
      • Using a Phillips #1 screwdriver, remove the single screw to the spring.
      • Once the spring is unscrewed, slowly pull it towards you, then to the left of the spring bracket to free the spring.
      Ask FixBot
    8. ZCWA BR151 Wheel Replacement: step 10, image 1 of 2 ZCWA BR151 Wheel Replacement: step 10, image 2 of 2
      • The wheel's motor is still attached to the motherboard of the device. Locate the wheel's wiring and the port connector on the motherboard.
      • Pinch the silver brackets and pull the wire casing away from the motherboard.
      • Remove the wheel from the vacuum.
      • Repeat Steps 6-10 to replace the wheel on the opposite side.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 95
All Time: 1,319
