ZCWA BR151 Velcro Replacement
    1. ZCWA BR151 Velcro Replacement, Velcro: step 1, image 1 of 2 ZCWA BR151 Velcro Replacement, Velcro: step 1, image 2 of 2
      • Turn off the device.
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      Ask FixBot
    2. ZCWA BR151 Velcro Replacement: step 2, image 1 of 1
      • Use a Jimmy to get underneath the velcro until you are able to push it up enough to grab.
      Ask FixBot
    3. ZCWA BR151 Velcro Replacement: step 3, image 1 of 1
      • Use tweezers to peel off the rest of the velcro.
      • If necessary, use the spudger to remove more of the adhesive beneath the velcro.
      Ask FixBot
      • You will need four velcro strips. Cut out two, 1-inch long strips of velcro.
      • Cut an additional two, 3-inch long strips.
      Ask FixBot
      • If your velcro strips already have an adhesive back, simply attach them to the top of the mop bracket.
      • If you are using a hot glue gun to attach your velcro, place a small section of glue where you want the velcro to go, then carefully press your piece down.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 531
