Introduction
If you need to install a new battery in your ZCWA BR151 vacuum, you can access the battery panel on the underside of the device using this guide. The battery is easily accessible, so there is no need to remove any additional parts to access it. You will not need to do any difficult steps, but extract the battery carefully.
Flip the device over to access the panels on the back.
Rotate the device to where the battery panel is closest to you.
Using a Phillips #1 screwdriver, remove the two 10 mm screws from the battery panel.
2 other people completed this guide.
3 Guide Comments
Where to buy the replacement battery and what is the part number
