Yuneec Typhoon H Plus Propeller Replacement
    1. Yuneec Typhoon H Plus Propeller Replacement, Propeller: step 1, image 1 of 1
      • Locate the broken propeller and figure out if it is a A-propeller or B-propeller.
      • An A-propeller will have a black button in the center and an A imprinted on the propeller.
      • A B-propeller will have a white button and a B imprinted on the propeller.
      • Though the A and B propellers are different the steps to replace one are the same.
      Ask FixBot
    2. Yuneec Typhoon H Plus Propeller Replacement: step 2, image 1 of 1
      • Press down on the button firmly.
      Ask FixBot
    3. Yuneec Typhoon H Plus Propeller Replacement: step 3, image 1 of 2 Yuneec Typhoon H Plus Propeller Replacement: step 3, image 2 of 2
      • Hold the base of the propeller with your pointer finger.
      • Make sure to continue to hold the button down. Rotate the propeller counter-clockwise, holding the base steady.
      • Lift the propeller off the drone.
      Ask FixBot
Brice Black
557 Reputation
4 Guides authored
Cal Poly, Team S2-G1, White Winter 2020 Member of Cal Poly, Team S2-G1, White Winter 2020
CPSU-WHITE-W20S2G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 462
