Yuneec ST16S Joystick Replacement
    1. Yuneec ST16S Joystick Replacement, Battery: step 1, image 1 of 1
      • Hold down the button located above the battery while applying downward pressure to the battery.
      Ask FixBot
    2. Yuneec ST16S Joystick Replacement: step 2, image 1 of 2 Yuneec ST16S Joystick Replacement: step 2, image 2 of 2
      • While still holding down the button, slide the battery out of its slot.
      Ask FixBot
    1. Yuneec ST16S Joystick Replacement, Backplate: step 3, image 1 of 1
      • Remove the single screw from the battery compartment.
      Ask FixBot
    2. Yuneec ST16S Joystick Replacement: step 4, image 1 of 2 Yuneec ST16S Joystick Replacement: step 4, image 2 of 2
      • Remove the rubber bumpers from the back of the device using a spudger.
      Ask FixBot
    3. Yuneec ST16S Joystick Replacement: step 5, image 1 of 2 Yuneec ST16S Joystick Replacement: step 5, image 2 of 2
      • Remove the two screws located under each of the rubber bumpers.
      Ask FixBot
    4. Yuneec ST16S Joystick Replacement: step 6, image 1 of 3 Yuneec ST16S Joystick Replacement: step 6, image 2 of 3 Yuneec ST16S Joystick Replacement: step 6, image 3 of 3
      • Remove the three screws along the top of the device.
      Ask FixBot
    5. Yuneec ST16S Joystick Replacement: step 7, image 1 of 2 Yuneec ST16S Joystick Replacement: step 7, image 2 of 2
      • Carefully remove the backplate from the device.
      Ask FixBot
    1. Yuneec ST16S Joystick Replacement, Joystick: step 8, image 1 of 1
      • Remove the four screws from around the joystick.
      Ask FixBot
    2. Yuneec ST16S Joystick Replacement: step 9, image 1 of 1
      • Unplug the joystick from the device.
      Ask FixBot
    3. Yuneec ST16S Joystick Replacement: step 10, image 1 of 1
      • Remove the joystick from the device.
      Ask FixBot
Christian Resendes
589 Reputation
5 Guides authored
UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 Member of UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 331
