Yuneec ST16S Cooling Fan Replacement
  1. Yuneec ST16S Cooling Fan Replacement, Battery: step 1, image 1 of 1
    • Hold down the button located above the battery while applying downward pressure to the battery.
    Ask FixBot
  2. Yuneec ST16S Cooling Fan Replacement: step 2, image 1 of 2 Yuneec ST16S Cooling Fan Replacement: step 2, image 2 of 2
    • While still holding down the button, slide the battery out of its slot.
    Ask FixBot
  3. Yuneec ST16S Cooling Fan Replacement, Backplate: step 3, image 1 of 1
    • Remove the single screw from the battery compartment.
    Ask FixBot
  4. Yuneec ST16S Cooling Fan Replacement: step 4, image 1 of 2 Yuneec ST16S Cooling Fan Replacement: step 4, image 2 of 2
    • Remove the rubber bumpers from the back of the device using a spudger.
    Ask FixBot
  5. Yuneec ST16S Cooling Fan Replacement: step 5, image 1 of 2 Yuneec ST16S Cooling Fan Replacement: step 5, image 2 of 2
    • Remove the two screws located under each of the rubber bumpers.
    Ask FixBot
  6. Yuneec ST16S Cooling Fan Replacement: step 6, image 1 of 3 Yuneec ST16S Cooling Fan Replacement: step 6, image 2 of 3 Yuneec ST16S Cooling Fan Replacement: step 6, image 3 of 3
    • Remove the three screws along the top of the device.
    Ask FixBot
  7. Yuneec ST16S Cooling Fan Replacement: step 7, image 1 of 2 Yuneec ST16S Cooling Fan Replacement: step 7, image 2 of 2
    • Carefully remove the backplate from the device.
    Ask FixBot
  8. Yuneec ST16S Cooling Fan Replacement, Cooling Fan: step 8, image 1 of 2 Yuneec ST16S Cooling Fan Replacement, Cooling Fan: step 8, image 2 of 2
    • Remove the screws from the metal bracket and around the cooling fan.
    Ask FixBot
  9. Yuneec ST16S Cooling Fan Replacement: step 9, image 1 of 1
    • Unplug the cooling fan from the device.
    Ask FixBot
  10. Yuneec ST16S Cooling Fan Replacement: step 10, image 1 of 1
    • Remove the cooling fan from the device.
    Ask FixBot
Christian Resendes
589 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 192
