Up to 20% off select tools
Yuneec ST16S Backplate Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
9
Past 30 Days:
50
All Time:
409
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is the backplate of your Yuneec ST16s damaged or broken and needs to be replaced? Use this guide to help you replace it.
This device is an all-inclusive transmitter and receiver that gives you full control over a H520 Hexacopter during flight. It allows users to capture photos and videos with great ease.
Backplates (if damaged) can pose a great risk of increasing overall damage to your device if left unreplaced.
Before starting, make sure the device is powered completely off.
    1. Yuneec ST16S Backplate Replacement, Backplate: step 1, image 1 of 1
      • Remove the single screw from the battery compartment.
      Ask FixBot
    2. Yuneec ST16S Backplate Replacement: step 2, image 1 of 2 Yuneec ST16S Backplate Replacement: step 2, image 2 of 2
      • Remove the rubber bumpers from the back of the device using a spudger.
      Ask FixBot
    3. Yuneec ST16S Backplate Replacement: step 3, image 1 of 2 Yuneec ST16S Backplate Replacement: step 3, image 2 of 2
      • Remove the two screws located under each of the rubber bumpers.
      Ask FixBot
    4. Yuneec ST16S Backplate Replacement: step 4, image 1 of 3 Yuneec ST16S Backplate Replacement: step 4, image 2 of 3 Yuneec ST16S Backplate Replacement: step 4, image 3 of 3
      • Remove the three screws along the top of the device.
      Ask FixBot
    5. Yuneec ST16S Backplate Replacement: step 5, image 1 of 2 Yuneec ST16S Backplate Replacement: step 5, image 2 of 2
      • Carefully remove the backplate from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Kristen Gismondi
110,433 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 50
All Time: 409
