Introduction
Go to step 1 ↓The Yuneec ST10 Plus is a ground station controller that depends on its screen to show camera views and flight information. If the screen is cracked, has water damage, or doesn’t respond to touch, this guide will help you replace it.
A broken screen can cause problems like blurry images, missing visuals, or touch controls that don’t work. This guide will show you, step by step, how to open the controller, remove the damaged screen, and install a new one.
Before you begin, check for loose or broken glass and make sure the controller is turned off.
Tools
Spudger4.9
Flip the controller upside down to access the battery compartment.
Grab the compartment door and pull down.
Slide the Jimmy underneath the rubber grips and pry upwards.
With your free hand grasp the rubber grips and pull upward to remove it.
