Yuneec Breeze 4K Motherboard Replacement
    1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: step 1, image 1 of 2 Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: step 1, image 2 of 2
      • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
      • Flip over the drone so that the propellers are facing down and the camera is facing up.
      Ask FixBot
    2. Yuneec Breeze 4K Motherboard Replacement: step 2, image 1 of 3 Yuneec Breeze 4K Motherboard Replacement: step 2, image 2 of 3 Yuneec Breeze 4K Motherboard Replacement: step 2, image 3 of 3
      • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
      Ask FixBot
    3. Yuneec Breeze 4K Motherboard Replacement: step 3, image 1 of 1
      • Remove the 4 rubber plugs that hold the drone and its internal parts together.
      • These plugs can be located in each corner of the drone, and are white.
      Ask FixBot
    4. Yuneec Breeze 4K Motherboard Replacement: step 4, image 1 of 1
      • Unplug the four cables that are connected on the top face of the frame.
      Ask FixBot
    5. Yuneec Breeze 4K Motherboard Replacement: step 5, image 1 of 2 Yuneec Breeze 4K Motherboard Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • The rest of the wires that are still connected can be unplugged.
      • Using a pair of tweezers they can be unplugged.
      Ask FixBot
    6. Yuneec Breeze 4K Motherboard Replacement: step 6, image 1 of 3 Yuneec Breeze 4K Motherboard Replacement: step 6, image 2 of 3 Yuneec Breeze 4K Motherboard Replacement: step 6, image 3 of 3
      • Lift up or tilt entire frame and mother board and unplug all the wires.
      Ask FixBot
    7. Yuneec Breeze 4K Motherboard Replacement: step 7, image 1 of 3 Yuneec Breeze 4K Motherboard Replacement: step 7, image 2 of 3 Yuneec Breeze 4K Motherboard Replacement: step 7, image 3 of 3
      • The battery connector has two wires connected to a plug in with two little screws.
      • Unscrew the two screws and pull it apart using a small tweezers.
      Ask FixBot
    8. Yuneec Breeze 4K Motherboard Replacement: step 8, image 1 of 1
      • Flip over the frame and mother board and unscrew the mother board.
      • There are four screws on each corner of the mother board.
      Ask FixBot
    9. Yuneec Breeze 4K Motherboard Replacement: step 9, image 1 of 2 Yuneec Breeze 4K Motherboard Replacement: step 9, image 2 of 2
      • After the screws are out, the motherboard can be pulled out softly with hands.
      • Remove the motherboard from the device.
      Ask FixBot
5 other people completed this guide.
Ryanne Millis
318 Reputation
1 Guide authored
UW Stout, Team S6-G5, Ogden Fall 2018 Member of UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Members
4 Guides authored
1 Guide Comment
Excellent step by step instructions.
paul_courville - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 2,586
