Yuneec Breeze 4K Camera Replacement
    1. Yuneec Breeze 4K Camera Replacement, Camera: step 1, image 1 of 2 Yuneec Breeze 4K Camera Replacement, Camera: step 1, image 2 of 2
      • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
      • Once the battery is taken out, flip over the drone so that the cameras are now facing up.
      Ask FixBot
    2. Yuneec Breeze 4K Camera Replacement: step 2, image 1 of 1
      • Using small pliers grip the connector of the wire and pull it out slowly.
      Ask FixBot
    3. Yuneec Breeze 4K Camera Replacement: step 3, image 1 of 1
      • Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
      Ask FixBot
    4. Yuneec Breeze 4K Camera Replacement: step 4, image 1 of 1
      • Unplug the two vertical plugs located in the rear of the M7 board.
      Ask FixBot
    5. Yuneec Breeze 4K Camera Replacement: step 5, image 1 of 1
      • Slightly lift the M7 board to remove the two plugs located under the rear of the board.
      Ask FixBot
    6. Yuneec Breeze 4K Camera Replacement: step 6, image 1 of 1
      • Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
      Ask FixBot
    7. Yuneec Breeze 4K Camera Replacement: step 7, image 1 of 2 Yuneec Breeze 4K Camera Replacement: step 7, image 2 of 2
      • Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
      Ask FixBot
    8. Yuneec Breeze 4K Camera Replacement: step 8, image 1 of 1
      • Using a pair of pliers pull apart the battery connector.
      Ask FixBot
    9. Yuneec Breeze 4K Camera Replacement: step 9, image 1 of 1
      • Flip over the entire frame along with the M7 board and the A9 board.
      Ask FixBot
    10. Yuneec Breeze 4K Camera Replacement: step 10, image 1 of 1
      • There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
      Ask FixBot
    11. Yuneec Breeze 4K Camera Replacement: step 11, image 1 of 1
      • Unplug the only wire that is connected to the A9 board.
      Ask FixBot
    12. Yuneec Breeze 4K Camera Replacement: step 12, image 1 of 1
      • Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
      Ask FixBot
    13. Yuneec Breeze 4K Camera Replacement: step 13, image 1 of 1
      • Unscrew the four screws that are holding the camera to the frame.
      Ask FixBot
3 other people completed this guide.
Wes Knutson
481 Reputation
3 Guides authored
UW Stout, Team S6-G5, Ogden Fall 2018 Member of UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Members
48 Guides authored
1 Guide Comment
Excellent! I don’t think that the process could of have been any more clear than this.
neonjohn25 - Reply Share
Past 24 Hours: 6
Past 7 Days: 8
Past 30 Days: 33
All Time: 2,466
