Yujin Robot iCLEBO Arte Power Transformer Replacement
    1. Yujin Robot iCLEBO Arte Power Transformer Replacement, Power Transformer: step 1, image 1 of 1
      • Unplug transformer before performing operations on it!
      • Press on the two black plastic tabs to remove the rear cover for the charging base.
      Ask FixBot
    2. Yujin Robot iCLEBO Arte Power Transformer Replacement: step 2, image 1 of 1
      • Remove the long cable from inside the base and gently pull the connector from the base.
      Ask FixBot
    3. Yujin Robot iCLEBO Arte Power Transformer Replacement: step 3, image 1 of 1
      • Pull out and remove the old cable from inside the charging base.
      • Detach the thicker part of the cord from the black transformer box.
      Ask FixBot
    4. Yujin Robot iCLEBO Arte Power Transformer Replacement: step 4, image 1 of 1
      • Replace the new thick cable with the old cable just removed. Make sure the cable can fit into the wall before discarding the other cable. If you are residing in the US, this is the connector you need to use.
      Ask FixBot
Trent Bingel
437 Reputation
4 Guides authored
USF Tampa, Team S2-G3, Nance Spring 2017 Member of USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 31
All Time: 878
