Yoton YB02 Monitor Speaker Replacement
    1. Yoton YB02 Monitor Speaker Replacement, Monitor Speaker: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four 7 mm screws from the back panel of the monitor.
      Ask FixBot
    2. Yoton YB02 Monitor Speaker Replacement: step 2, image 1 of 2 Yoton YB02 Monitor Speaker Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to separate the back panel from the monitor.
      • It is recommended to start from a corner, and run the tool along the edge of the panel.
      Ask FixBot
    3. Yoton YB02 Monitor Speaker Replacement: step 3, image 1 of 2 Yoton YB02 Monitor Speaker Replacement: step 3, image 2 of 2
      • Using the plastic tool, disconnect the cables connecting the speaker to the motherboard.
      Ask FixBot
    4. Yoton YB02 Monitor Speaker Replacement: step 4, image 1 of 2 Yoton YB02 Monitor Speaker Replacement: step 4, image 2 of 2
      • Using the metal spudger, pry off the speaker from the back panel.
      • It is recommended to scrape off excess glue holding the speaker to the panel with the spudger.
      Ask FixBot
hsisson
811 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 45
All Time: 326
