Yoton YB02 Microphone Replacement
    1. Yoton YB02 Microphone Replacement, Microphone: step 1, image 1 of 2 Yoton YB02 Microphone Replacement, Microphone: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the single 7 mm screw from the back of the panel from the camera.
      Ask FixBot
    2. Yoton YB02 Microphone Replacement: step 2, image 1 of 1
      • Use a metal spudger to pry off the back panel from the camera.
      • It is recommended to pry at the edges of the panel and run through the edge of the panel.
      Ask FixBot
    3. Yoton YB02 Microphone Replacement: step 3, image 1 of 2 Yoton YB02 Microphone Replacement: step 3, image 2 of 2
      • With the soldering iron, desolder the pin holding the microphone in place on the motherboard.
      Ask FixBot
    4. Yoton YB02 Microphone Replacement: step 4, image 1 of 3 Yoton YB02 Microphone Replacement: step 4, image 2 of 3 Yoton YB02 Microphone Replacement: step 4, image 3 of 3
      • Carefully slide the microphone and microphone cable through the back panel.
      Ask FixBot
hsisson
811 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 26
All Time: 330
