Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓This guide will provide a step by step process to replace the left or right trigger spring in a Yobo Gameware controller for the Nintendo GameCube.
Place the controller (button - side down) on a clean, solid work surface.
Use your screwdriver to remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Depress the trigger assembly using your index finger while using your thumb to keep upward pressure on the grey square bracket and clear circular component on the underside of the trigger assembly.
Rotate the assembly upwards and towards you to remove it from its housing in the controller.
Gently release pressure on the trigger assembly, allowing the components to come apart on your work surface.
A new spring may now be incorporated into the designated trigger assembly.
