Yamaha YPG-225 Keys Replacement
    1. Yamaha YPG-225 Keys Replacement, Batteries: step 1, image 1 of 1
      • Turn the keyboard over so that the keys are facing the ground.
      Ask FixBot
    2. Yamaha YPG-225 Keys Replacement: step 2, image 1 of 1
      • Pop the tabs on the battery casing and remove it from the back plate.
      Ask FixBot
    3. Yamaha YPG-225 Keys Replacement: step 3, image 1 of 1
      • Locate the six batteries and remove them from the battery cavity.
      Ask FixBot
    1. Yamaha YPG-225 Keys Replacement, Faceplate: step 4, image 1 of 1
      • Remove the six 10mm screws at the top of the backplate.
      Ask FixBot
    2. Yamaha YPG-225 Keys Replacement: step 5, image 1 of 1
      • Remove the seven 12mm screws in the middle of the back plate.
      Ask FixBot
    3. Yamaha YPG-225 Keys Replacement: step 6, image 1 of 1
      • Remove the eight 10mm screws from the side and the bottom of the back plate.
      Ask FixBot
    4. Yamaha YPG-225 Keys Replacement: step 7, image 1 of 1
      • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
      • Flip over the keyboard.
      Ask FixBot
    5. Yamaha YPG-225 Keys Replacement: step 8, image 1 of 2 Yamaha YPG-225 Keys Replacement: step 8, image 2 of 2
      • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
      • Be careful when removing the face plate. There are wires attached.
      Ask FixBot
    1. Yamaha YPG-225 Keys Replacement, Keys: step 9, image 1 of 1
      • Remove the 32mm screws that hold keys down.
      • Depending on which block of keys you wish to remove, there may be four screws instead of three.
      Ask FixBot
    2. Yamaha YPG-225 Keys Replacement: step 10, image 1 of 1
      • Remove the block of keys that holds the key you wish to install.
      • To do this, apply a small force away from the top of the keys and slightly toward the floor.
      • If done correctly, the block of keys will come to a slight downward angle.
      Ask FixBot
    3. Yamaha YPG-225 Keys Replacement: step 11, image 1 of 2 Yamaha YPG-225 Keys Replacement: step 11, image 2 of 2
      • Press the tab on the back side of the block of keys out and detach the black keys.
      Ask FixBot
    4. Yamaha YPG-225 Keys Replacement: step 12, image 1 of 1
      • Remove the individual white key(s) or the black key set(s) that require replacement.
      Ask FixBot
7 other people completed this guide.
Kevin Green
308 Reputation
2 Guides authored
Cal Poly, Team 2-62, Propen Fall 2012 Member of Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 Members
42 Guides authored
3 Guide Comments
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - Reply Share
Great article. Thank you so much.
Andreas Devig - Reply Share
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 35
All Time: 21,985
