Yamaha NS-AW190BL Input/Output Panel Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
80
All Time:
1,217
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing the input/output panel.
Tools
    1. Yamaha NS-AW190BL Input/Output Panel Replacement, Input/Output Panel: step 1, image 1 of 2 Yamaha NS-AW190BL Input/Output Panel Replacement, Input/Output Panel: step 1, image 2 of 2
      • Remove all four .5 mm Phillips head screws located on the back panel of the device.
      • Pull out the input/output panel from the back of the device once all four screws are removed.
      Ask FixBot
    2. Yamaha NS-AW190BL Input/Output Panel Replacement: step 2, image 1 of 3 Yamaha NS-AW190BL Input/Output Panel Replacement: step 2, image 2 of 3 Yamaha NS-AW190BL Input/Output Panel Replacement: step 2, image 3 of 3
      • Gently push down on the tab holding the connectors together.
      • Repeat the process on the second connector. (Even though they appear different, they are held together using the same tabs.)
      • Remove both connectors to free the input/output panel.
      Ask FixBot
bradley
101 Reputation
1 Guide authored
USF Tampa, Team 17-3, Blackwell Spring 2017 Member of USF Tampa, Team 17-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 80
All Time: 1,217
