Yamaha FG-425 Guitar String Replacement
    1. Yamaha FG-425 Guitar String Replacement, Guitar String: step 1, image 1 of 3 Yamaha FG-425 Guitar String Replacement, Guitar String: step 1, image 2 of 3 Yamaha FG-425 Guitar String Replacement, Guitar String: step 1, image 3 of 3
      • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
      • Unwind the string from the tuning post and remove the string.
      • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
      Ask FixBot
    2. Yamaha FG-425 Guitar String Replacement: step 2, image 1 of 2 Yamaha FG-425 Guitar String Replacement: step 2, image 2 of 2
      • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
      • Remove the string from the bridge hole.
      Ask FixBot
    3. Yamaha FG-425 Guitar String Replacement: step 3, image 1 of 2 Yamaha FG-425 Guitar String Replacement: step 3, image 2 of 2
      • Bend the string end on the string ball.
      • Place the string into the bridge hole.
      Ask FixBot
    4. Yamaha FG-425 Guitar String Replacement: step 4, image 1 of 3 Yamaha FG-425 Guitar String Replacement: step 4, image 2 of 3 Yamaha FG-425 Guitar String Replacement: step 4, image 3 of 3
      • Place the bridge pin into the bridge hole.
      • Gently pull the string while pushing the pin into the hole.
      Ask FixBot
    5. Yamaha FG-425 Guitar String Replacement: step 5, image 1 of 2 Yamaha FG-425 Guitar String Replacement: step 5, image 2 of 2
      • Insert the string through the tuning post hole.
      • Pull the string about half an inch or an inch through the tuning post.
      • Ensure that the string is lined up with the nut.
      Ask FixBot
    6. Yamaha FG-425 Guitar String Replacement: step 6, image 1 of 1
      • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
      Ask FixBot
    7. Yamaha FG-425 Guitar String Replacement: step 7, image 1 of 1
      • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
      Ask FixBot
Finish Line
Nicole Francheska Letigio
207 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 40
All Time: 738
