Up to 20% off select tools
Yamaha DM1000 Faders Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
9
Past 7 Days:
39
Past 30 Days:
178
All Time:
4,325
Comments: 14
14 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 4 hours
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Open the console and replacing the faders, step by step. This job need soldering skills an couple of hour.
    1. Yamaha DM1000 Faders Replacement, Remove wood  panels (Assuming you have it): step 1, image 1 of 2 Yamaha DM1000 Faders Replacement, Remove wood  panels (Assuming you have it): step 1, image 2 of 2
      • Remove 5 screws:
      • Three screws for the lower part
      • Two screws for the upper part
      • Use a #4 Phillips screwdriver.
      Ask FixBot
    2. Yamaha DM1000 Faders Replacement, Remove meter (if you have one): step 2, image 1 of 2 Yamaha DM1000 Faders Replacement, Remove meter (if you have one): step 2, image 2 of 2
      • Remove sub-d connector from bargraph.
      • Remove 4 screws (2shorts/2 long) from metal bracket and mixing desk.
      Ask FixBot
    3. Yamaha DM1000 Faders Replacement, Remove side panels: step 3, image 1 of 1
      • Remove 15 screws:
      • Remove 1 smaller screw
      • remove Phillip screw #2
      • Attention: these are self-tapping screws => risk of creating chips when screwing.
      Ask FixBot
    4. Yamaha DM1000 Faders Replacement, Remove fader button + front & back screws: step 4, image 1 of 3 Yamaha DM1000 Faders Replacement, Remove fader button + front & back screws: step 4, image 2 of 3 Yamaha DM1000 Faders Replacement, Remove fader button + front & back screws: step 4, image 3 of 3
      • remove 16 + 1 fader with fingers or a with a plastic card.
      • remove 4 screws at the back.
      • remove 4 screws at the front (bad pic here).
      Ask FixBot
    5. Yamaha DM1000 Faders Replacement, Remove 4 cables before opening: step 5, image 1 of 2 Yamaha DM1000 Faders Replacement, Remove 4 cables before opening: step 5, image 2 of 2
      • remove carrefully from the side the 2 withe connectors.
      • remove carrefully 2 cables from the power unit, unlock first the connector.
      Ask FixBot
    6. Yamaha DM1000 Faders Replacement, Opening the  console: step 6, image 1 of 3 Yamaha DM1000 Faders Replacement, Opening the  console: step 6, image 2 of 3 Yamaha DM1000 Faders Replacement, Opening the  console: step 6, image 3 of 3
      • open carefully the console from back to front by graping the sides.
      • open connectors and remove 5 cables.
      • you can now remove the upper part of the console.
      Ask FixBot
    7. Yamaha DM1000 Faders Replacement, Removing the circuit board: step 7, image 1 of 3 Yamaha DM1000 Faders Replacement, Removing the circuit board: step 7, image 2 of 3 Yamaha DM1000 Faders Replacement, Removing the circuit board: step 7, image 3 of 3
      • Cut the plastic clamps. Their are 4 clamps in the corners and 1 clamp holding flat cable in place.
      • Unscrew the 10 screws with a Phillips #2 screwdriver.
      Ask FixBot
    8. Yamaha DM1000 Faders Replacement, Removing Fader  cover: step 8, image 1 of 1
      • For each fader remove the 2 blacks screws with a philips #2.
      Ask FixBot
    9. Yamaha DM1000 Faders Replacement, Remove  cover + fader: step 9, image 1 of 2 Yamaha DM1000 Faders Replacement, Remove  cover + fader: step 9, image 2 of 2
      • remove solder from 4 metal bracket that are fixed to the PCB from the cover.
      • remove solder with a pump from 6 pin of the fader.
      • remove solder from the 2 pin of the motor of the fader.
      Ask FixBot
    10. Yamaha DM1000 Faders Replacement, Replace transistors: step 10, image 1 of 1
      • Replace transistors by new ones.
      • 2SB1181.
      • 2SD1733.
      • they are hard to find as the are being obsolete.
      Ask FixBot
    11. Yamaha DM1000 Faders Replacement, Add more  reliability: step 11, image 1 of 1
      • An idea from web forum from a Yamaha Technician that propose to add 4X 1N4148 diode by fader to protect the transistor. as free wheel.
      • add diode between base and collector as show here.
      Ask FixBot
To reassemble your device follow the following instructions in reverse order.
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
F. Jeanneret
276 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 178
All Time: 4,325
