YORK TM9Y080B12MP11 Furnace Filter Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
10
Past 7 Days:
38
Past 30 Days:
137
All Time:
2,802
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through how to change the filter on your YORK TM9Y080B12MP11 Furnace. This guide uses an Aprilaire Model 413 Filter.
It is important to replace the filter in your furnace as overtime dust and debris will build up and will enter the air ducts and home. This can lead to polluted and dirty air which can lead to a variety of issues including potential respiratory issues and triggering of allergies. Typically, furnace filters should be replaced around every month, however this will vary.
The process laid out in this guide will have you turning off the furnace, removing the old filter, inserting the new filter and then turning the furnace back on.
This guide requires no tools or prior experience replacing or fixing items.
    1. YORK TM9Y080B12MP11 Furnace Filter Replacement, Filter: step 1, image 1 of 1
      • Turn off the furnace by either using the switch near to the furnace or by turning the temperature down with the thermostat.
      Ask FixBot
    2. YORK TM9Y080B12MP11 Furnace Filter Replacement: step 2, image 1 of 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: step 2, image 2 of 2
      • Pull the handhold with force in order to open the 'door' to the filter's location.
      • You will hear a 'pop' and the door should come off easily.
      Ask FixBot
    3. YORK TM9Y080B12MP11 Furnace Filter Replacement: step 3, image 1 of 3 YORK TM9Y080B12MP11 Furnace Filter Replacement: step 3, image 2 of 3 YORK TM9Y080B12MP11 Furnace Filter Replacement: step 3, image 3 of 3
      • Remove the old filter completely by pulling the filter out of its location.
      • On the top of the filter there is an arrow pointing in a specific direction. Make sure you remember that direction.
      Ask FixBot
    4. YORK TM9Y080B12MP11 Furnace Filter Replacement: step 4, image 1 of 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: step 4, image 2 of 2
      • Insert the new filter by sliding it into the same place where the old filter was.
      • Make sure that the arrow on the top of the filter is pointing in the same direction as the old filter was.
      • Make sure that the filter is as far back as it can go.
      Ask FixBot
    5. YORK TM9Y080B12MP11 Furnace Filter Replacement: step 5, image 1 of 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: step 5, image 2 of 2
      • Reattach the door by lining it up with the inside edges of the opening.
      • Use force to make sure that the door is fully secure into its position so that the door does not fall off. You should hear a sound similar to a click once the door is correctly in place.
      Ask FixBot
    6. YORK TM9Y080B12MP11 Furnace Filter Replacement: step 6, image 1 of 1
      • Turn back on the furnace.
      • You can do this by flipping the switch back on or by turning the furnace on with the thermostat.
      Ask FixBot
Finish Line
DevBos
133 Reputation
1 Guide authored
1 Guide Comment
very good explanation
5 Stars hvac services - Reply Share
Past 24 Hours: 10
Past 7 Days: 38
Past 30 Days: 137
All Time: 2,802
