YCCTEAM YCC-SW4001 Vibration Motor Replacement
  1. YCCTEAM YCC-SW4001 Vibration Motor Replacement, Front Case: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
    Ask FixBot
  2. YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 2, image 1 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 2, image 2 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 2, image 3 of 3
    • Use an opening pick to pry the back cover off of the controller.
    Ask FixBot
  3. YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 3, image 1 of 1
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
    Ask FixBot
  4. YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 4, image 1 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 4, image 2 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 4, image 3 of 3
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
    Ask FixBot
  5. YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 5, image 1 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 5, image 2 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 5, image 3 of 3
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
    Ask FixBot
  6. YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 6, image 1 of 2 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 6, image 2 of 2
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
    Ask FixBot
  7. YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 7, image 1 of 1
    • Remove the front case.
    Ask FixBot
  8. YCCTEAM YCC-SW4001 Vibration Motor Replacement, Vibration Motor: step 8, image 1 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement, Vibration Motor: step 8, image 2 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement, Vibration Motor: step 8, image 3 of 3
    • On the front side, disconnect the two vibration motor motherboard connectors.
    • Do not pull on the wires.
    • When replacing the rumble motors, press each plug down into its socket until it snaps into place.
    Ask FixBot
  9. YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 9, image 1 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 9, image 2 of 3 YCCTEAM YCC-SW4001 Vibration Motor Replacement: step 9, image 3 of 3
    • Remove the rumble motors from the controller grips.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 39
All Time: 248
