Up to 20% off select tools
YCCTEAM YCC-SW4001 Front Case Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
65
All Time:
567
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you need to replace any of the components within the YCCTEAM YCC-SW4001, you will need to remove the front cover first.
The front cover is an important part of the controller. It includes the ABXY buttons, shoulder buttons, and connects to the back cover via a ribbon cable. This component is often replaced or modified for cosmetic purposes.
Exercise caution when removing the ribbon cable, as there is a component that needs to be carefully moved and can easily be broken.
    1. YCCTEAM YCC-SW4001 Front Case Replacement, Front Case: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
      Ask FixBot
    2. YCCTEAM YCC-SW4001 Front Case Replacement: step 2, image 1 of 3 YCCTEAM YCC-SW4001 Front Case Replacement: step 2, image 2 of 3 YCCTEAM YCC-SW4001 Front Case Replacement: step 2, image 3 of 3
      • Use an opening pick to pry the back cover off of the controller.
      Ask FixBot
    3. YCCTEAM YCC-SW4001 Front Case Replacement: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
      Ask FixBot
    4. YCCTEAM YCC-SW4001 Front Case Replacement, Remove two additional screws: step 4, image 1 of 1
      • On some models there are two more Phillips head screws on the sides that need to be removed before the front and back panels can be separated.
      Ask FixBot
    5. YCCTEAM YCC-SW4001 Front Case Replacement: step 5, image 1 of 3 YCCTEAM YCC-SW4001 Front Case Replacement: step 5, image 2 of 3 YCCTEAM YCC-SW4001 Front Case Replacement: step 5, image 3 of 3
      • Slightly lift the front case.
      • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
      Ask FixBot
    6. YCCTEAM YCC-SW4001 Front Case Replacement: step 6, image 1 of 3 YCCTEAM YCC-SW4001 Front Case Replacement: step 6, image 2 of 3 YCCTEAM YCC-SW4001 Front Case Replacement: step 6, image 3 of 3
      • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
      • The black flap holds the white ribbon cable in place.
      Ask FixBot
    7. YCCTEAM YCC-SW4001 Front Case Replacement: step 7, image 1 of 2 YCCTEAM YCC-SW4001 Front Case Replacement: step 7, image 2 of 2
      • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
      Ask FixBot
    8. YCCTEAM YCC-SW4001 Front Case Replacement: step 8, image 1 of 1
      • Remove the front case.
      Ask FixBot
Author
with
David Adaway
537 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 65
All Time: 567
