YCCTEAM YCC-SW4001 ABXY Buttons Replacement
    1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Front Case: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
      Ask FixBot
    2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 2, image 1 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 2, image 2 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 2, image 3 of 3
      • Use an opening pick to pry the back cover off of the controller.
      Ask FixBot
    3. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
      Ask FixBot
    4. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Remove two additional screws: step 4, image 1 of 1
      • On some models there are two more Phillips head screws on the sides that need to be removed before the front and back panels can be separated.
      Ask FixBot
    5. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 5, image 1 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 5, image 2 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 5, image 3 of 3
      • Slightly lift the front case.
      • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
      Ask FixBot
    6. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 6, image 1 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 6, image 2 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 6, image 3 of 3
      • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
      • The black flap holds the white ribbon cable in place.
      Ask FixBot
    7. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 7, image 1 of 2 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 7, image 2 of 2
      • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
      Ask FixBot
    8. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 8, image 1 of 1
      • Remove the front case.
      Ask FixBot
    1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: step 9, image 1 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: step 9, image 2 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: step 9, image 3 of 3
      • Isolate the front cover.
      • Flip over the front cover and remove the four 5.77 mm screws from the back of the front cover using the Phillips #1 Screwdriver.
      Ask FixBot
    2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 10, image 1 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 10, image 2 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 10, image 3 of 3
      • Lift the circuit board from the front cover to expose the back of the buttons.
      Ask FixBot
    3. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 11, image 1 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 11, image 2 of 3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: step 11, image 3 of 3
      • Remove the rubber caps and the button caps by either dumping them out or taking them out by hand.
      Ask FixBot
Sam Borwick
333 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 544
