Xiaomi Yi Front Panel Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
105
All Time:
3,572
Comments: 3
3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The front panel is attached to the main case of the camera. It can be removed with a small blue plastic opening tool.
The front panel does not include the lens, but does allow you access to other internal parts of the camera; or, to replace a damaged front panel.
Tools
    1. Xiaomi Yi Front Panel Replacement, Battery: step 1, image 1 of 2 Xiaomi Yi Front Panel Replacement, Battery: step 1, image 2 of 2
      • Push the battery door switch to the left.
      • Lift the battery door up.
      Ask FixBot
    2. Xiaomi Yi Front Panel Replacement: step 2, image 1 of 3 Xiaomi Yi Front Panel Replacement: step 2, image 2 of 3 Xiaomi Yi Front Panel Replacement: step 2, image 3 of 3
      • Lift the battery tab up.
      • Remove the battery by pulling the removal tab.
      Ask FixBot
    1. Xiaomi Yi Front Panel Replacement, Front Panel: step 3, image 1 of 2 Xiaomi Yi Front Panel Replacement, Front Panel: step 3, image 2 of 2
      • Introduce the plastic opening tool into any of the sides of the camera.
      • Pry with the plastic opening tool at the seam between the front and the back panel.
      Ask FixBot
    2. Xiaomi Yi Front Panel Replacement: step 4, image 1 of 3 Xiaomi Yi Front Panel Replacement: step 4, image 2 of 3 Xiaomi Yi Front Panel Replacement: step 4, image 3 of 3
      • Slide prying tool along the seam until front panel is fully separated from the back panel.
      Ask FixBot
5 other people completed this guide.
William Zipperer
711 Reputation
3 Guides authored
USF Tampa, Team 15-5, Blackwell Fall 2015 Member of USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Members
60 Guides authored
3 Guide Comments
Where do you get a spare front panel, the small plastic hooks break easily
ltkipras - Reply Share
I would like to know too because i had a crash and i lost the ring that goes around the lens.
fabiocastroam - Reply Share
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
shguro - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 105
All Time: 3,572
