Xiaomi Yi Back Panel Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
105
All Time:
4,716
Comments: 2
2 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your camera's back case is damaged, you might consider changing it. To remove the back panel you will need a small blue plastic opening tool.
Tools
    1. Xiaomi Yi Back Panel Replacement, Battery: step 1, image 1 of 2 Xiaomi Yi Back Panel Replacement, Battery: step 1, image 2 of 2
      • Push the battery door switch to the left.
      • Lift the battery door up.
      Ask FixBot
    2. Xiaomi Yi Back Panel Replacement: step 2, image 1 of 3 Xiaomi Yi Back Panel Replacement: step 2, image 2 of 3 Xiaomi Yi Back Panel Replacement: step 2, image 3 of 3
      • Lift the battery tab up.
      • Remove the battery by pulling the removal tab.
      Ask FixBot
    1. Xiaomi Yi Back Panel Replacement, Front Panel: step 3, image 1 of 2 Xiaomi Yi Back Panel Replacement, Front Panel: step 3, image 2 of 2
      • Introduce the plastic opening tool into any of the sides of the camera.
      • Pry with the plastic opening tool at the seam between the front and the back panel.
      Ask FixBot
    2. Xiaomi Yi Back Panel Replacement: step 4, image 1 of 3 Xiaomi Yi Back Panel Replacement: step 4, image 2 of 3 Xiaomi Yi Back Panel Replacement: step 4, image 3 of 3
      • Slide prying tool along the seam until front panel is fully separated from the back panel.
      Ask FixBot
    1. Xiaomi Yi Back Panel Replacement, Back Panel: step 5, image 1 of 2 Xiaomi Yi Back Panel Replacement, Back Panel: step 5, image 2 of 2
      • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
      Ask FixBot
    2. Xiaomi Yi Back Panel Replacement: step 6, image 1 of 3 Xiaomi Yi Back Panel Replacement: step 6, image 2 of 3 Xiaomi Yi Back Panel Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
      Ask FixBot
    3. Xiaomi Yi Back Panel Replacement: step 7, image 1 of 2 Xiaomi Yi Back Panel Replacement: step 7, image 2 of 2
      • Remove the motherboard from from the back case by gently pulling on the lens housing.
      • Back panel remains.
      Ask FixBot
10 other people completed this guide.
Karol Gonzalez
379 Reputation
1 Guide authored
USF Tampa, Team 15-5, Blackwell Fall 2015 Member of USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Members
60 Guides authored
2 Guide Comments
Where can I buy back panel for Xiaomi Yi?
matulek - Reply Share
Where can i buy the back panel replacement ?
Roland Meilleur - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 105
All Time: 4,716
