Xiaomi Redmi Note Motherboard Replacement
    1. Xiaomi Redmi Note Motherboard Replacement, Battery: step 1, image 1 of 1
      • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
      • Insert the plastic opening tool between the charging port and the rear case.
      • Pry the end of the rear case up from the charging port.
      Ask FixBot
    2. Xiaomi Redmi Note Motherboard Replacement: step 2, image 1 of 2 Xiaomi Redmi Note Motherboard Replacement: step 2, image 2 of 2
      • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
      Ask FixBot
    3. Xiaomi Redmi Note Motherboard Replacement: step 3, image 1 of 2 Xiaomi Redmi Note Motherboard Replacement: step 3, image 2 of 2
      • Locate the indentation at the bottom of the battery.
      • Place a finger in the indentation and lift up to remove the battery.
      Ask FixBot
    1. Xiaomi Redmi Note Motherboard Replacement, Midframe: step 4, image 1 of 2 Xiaomi Redmi Note Motherboard Replacement, Midframe: step 4, image 2 of 2
      • Remove twelve 3.5mm Phillips #00 screws from the midframe.
      Ask FixBot
    2. Xiaomi Redmi Note Motherboard Replacement: step 5, image 1 of 2 Xiaomi Redmi Note Motherboard Replacement: step 5, image 2 of 2
      • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
      • Run the plastic opening tool along the seam.
      • Pry up the midframe with the plastic opening tool.
      • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
      • There will be snapping sounds as the clips on the midframe disconnect from the phone.
      Ask FixBot
    1. Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: step 6, image 1 of 3 Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: step 6, image 2 of 3 Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
      • Use tweezers to pull the ribbon cable out of the ZIF connector.
      • Remove the front-facing camera from the motherboard.
      Ask FixBot
    1. Xiaomi Redmi Note Motherboard Replacement, Rear Camera: step 7, image 1 of 2 Xiaomi Redmi Note Motherboard Replacement, Rear Camera: step 7, image 2 of 2
      • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
      Ask FixBot
    1. Xiaomi Redmi Note Motherboard Replacement, Motherboard: step 8, image 1 of 1
      • Locate the three ZIF connectors on the motherboard.
      Ask FixBot
    2. Xiaomi Redmi Note Motherboard Replacement: step 9, image 1 of 3 Xiaomi Redmi Note Motherboard Replacement: step 9, image 2 of 3 Xiaomi Redmi Note Motherboard Replacement: step 9, image 3 of 3
      Buy
      • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
      • Pull the ribbon cable out of the connector by pulling to the left.
      • Repeat these steps for the other two ZIF connectors.
      Ask FixBot
    3. Xiaomi Redmi Note Motherboard Replacement: step 10, image 1 of 3 Xiaomi Redmi Note Motherboard Replacement: step 10, image 2 of 3 Xiaomi Redmi Note Motherboard Replacement: step 10, image 3 of 3
      • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
      Ask FixBot
    4. Xiaomi Redmi Note Motherboard Replacement: step 11, image 1 of 2 Xiaomi Redmi Note Motherboard Replacement: step 11, image 2 of 2
      • Remove the two 2.9mm Philips #00 screws.
      Ask FixBot
    5. Xiaomi Redmi Note Motherboard Replacement: step 12, image 1 of 3 Xiaomi Redmi Note Motherboard Replacement: step 12, image 2 of 3 Xiaomi Redmi Note Motherboard Replacement: step 12, image 3 of 3
      • Flip over the motherboard to reveal the back.
      • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
      Ask FixBot
    6. Xiaomi Redmi Note Motherboard Replacement: step 13, image 1 of 2 Xiaomi Redmi Note Motherboard Replacement: step 13, image 2 of 2
      • Lift up the motherboard and turn it over to place it by the side of the phone.
      • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
      Ask FixBot
    7. Xiaomi Redmi Note Motherboard Replacement: step 14, image 1 of 3 Xiaomi Redmi Note Motherboard Replacement: step 14, image 2 of 3 Xiaomi Redmi Note Motherboard Replacement: step 14, image 3 of 3
      • Use tweezers to peel the vibrating motor off the frame of the phone.
      • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
      Ask FixBot
16 other people completed this guide.
AJ Beers
213 Reputation
2 Guides authored
Cal Poly, Team S22-G4, Livingston Spring 2017 Member of Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Members
96 Guides authored
5 Guide Comments
Good explanation, but the question is : Where to get Xiaomi replacement motherboards ?
Adriano Fonseca - Reply Share
can we shift bords memory to other bord
krishna - Reply Share
No we can't get motherboard's memory if it is damaged
sai teja - Reply Share
Besten Dank an alle für Die Mühe, die sie sich jeweils geben um verständliche Anleitungen zu erstellen,
Oigres Ailgevar - Reply Share
Past 24 Hours: 6
Past 7 Days: 60
Past 30 Days: 237
All Time: 27,691
