Xiaomi Redmi Note 9 Fingerprint Sensor Replacement
    1. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Eject the SIM card tray: step 1, image 1 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Eject the SIM card tray: step 1, image 2 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Eject the SIM card tray: step 1, image 3 of 3
      • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
      • Press directly into the hole to eject the SIM card tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Heat the back cover: step 2, image 1 of 1
      • The back cover of the Redmi Note 9 is held in place by plastic clips and adhesive. It might require some force to release the plastic clips.
      • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Insert an opening pick: step 3, image 1 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Insert an opening pick: step 3, image 2 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Insert an opening pick: step 3, image 3 of 3
      • Secure a suction handle to the bottom edge of the screen, as close to the edge as possible.
      • If the screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the screen and phone assembly with the suction handle to create a small gap between the assembly and the back cover.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick in a steep angle into the gap you created. This might require some force.
      • Slide the opening pick to the bottom right corner to slice the adhesive and release the plastic clips holding the back cover in place.
      Ask FixBot
    3. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Release the plastic clips and slice the adhesive: step 4, image 1 of 2 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Release the plastic clips and slice the adhesive: step 4, image 2 of 2
      • Insert a second opening pick in a steep angle at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to release the plastic clips and to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Release the plastic clips and slice the adhesive: step 5, image 1 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Release the plastic clips and slice the adhesive: step 5, image 2 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Release the plastic clips and slice the adhesive: step 5, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Slide the bottom left opening pick along the left edge of your phone to release the plastic clips and slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement: step 6, image 1 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement: step 6, image 2 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement: step 6, image 3 of 3
      • Slide the bottom right opening pick along the right edge of your phone to release the plastic clips and slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      • Do not try to separate the phone assembly from the back cover all the way yet, the fingerprint reader is still adhered to the back cover.
      Ask FixBot
    6. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Heat the fingerprint reader: step 7, image 1 of 1
      • Prepare an iOpener and apply it to the back cover where the fingerprint reader is located for at least two minutes to loosen the adhesive underneath.
      Ask FixBot
    7. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Remove the back cover: step 8, image 1 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Remove the back cover: step 8, image 2 of 3 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Remove the back cover: step 8, image 3 of 3
      • Carefully lift the back cover upwards whilst pressing down the fingerprint reader with a finger.
      • The fingerprint reader should separate from the back cover during this procedure. In case the adhesive is too strong, you can reapply a heated iOpener to the fingerprint reader for one to two minutes to further loosen its adhesive.
      • Remove the back cover.
      • Secure a new back cover with pre-cut adhesive or double-sided adhesive tape. Apply the new adhesive into the back cover and not onto the frame of the phone assembly. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Loosen the fingerprint sensor: step 9, image 1 of 2 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Loosen the fingerprint sensor: step 9, image 2 of 2
      • The fingerprint sensor is held in place by mild adhesive.
      • Slide the tip of an opening pick underneath the fingerprint sensor and pry it up to separate it from the motherboard cover.
      Ask FixBot
    2. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Unfasten the motherboard cover screws: step 10, image 1 of 1
      • Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
      Ask FixBot
    3. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Pry up the motherboard cover: step 11, image 1 of 2 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Pry up the motherboard cover: step 11, image 2 of 2
      • Insert the tip of an opening pick underneath the bottom left edge of the motherboard cover.
      • Pry up the motherboard cover.
      Ask FixBot
    4. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Remove the motherboard cover: step 12, image 1 of 2 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Remove the motherboard cover: step 12, image 2 of 2
      • Carefully remove the motherboard cover.
      • Take care not to strain the finger print cable during this procedure. In the meantime the fingerprint sensor might adhered to the motherboard cover again and needs to be loosed before removing the cover.
      Ask FixBot
    5. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Disconnect the fingerprint cable: step 13, image 1 of 2 Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Disconnect the fingerprint cable: step 13, image 2 of 2
      • Use a spudger to disconnect the fingerprint cable by prying the connector straight up from its socket.
      Ask FixBot
    6. Xiaomi Redmi Note 9 Fingerprint Sensor Replacement, Remove the fingerprint sensor: step 14, image 1 of 1
      • Remove the fingerprint sensor.
      • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
5 other people completed this guide.
Dominik Schnabelrauch
266,047 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
1 Guide Comment
হারিছ চৌধুরী বাজার নোয়াখালী
Mr Abdul ahad - Reply Share
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 127
All Time: 4,325
