Up to 20% off select tools
Xiaomi Redmi Note 7 Screen Replacement
Views: 24K
View statistics:
Past 24 Hours:
7
Past 7 Days:
51
Past 30 Days:
283
All Time:
24,284
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or broken screen on your Xiaomi Redmi Note 7.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
    1. Xiaomi Redmi Note 7 Screen Replacement, Loosen the rear glass adhesive: step 1, image 1 of 1
      • Apply a heated iOpener to the rear glass to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
      • If your rear glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the rear glass.
      • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      Ask FixBot
    3. Xiaomi Redmi Note 7 Screen Replacement, Slice the bottom edge adhesive: step 3, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Slice the bottom edge adhesive: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Xiaomi Redmi Note 7 Screen Replacement, Slice the lefthand-side adhesive: step 4, image 1 of 3 Xiaomi Redmi Note 7 Screen Replacement, Slice the lefthand-side adhesive: step 4, image 2 of 3 Xiaomi Redmi Note 7 Screen Replacement, Slice the lefthand-side adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom left corner.
      • Slide the opening pick along the left edge of the phone to slice the rear glass adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Redmi Note 7 Screen Replacement, Slice the top edge adhesive: step 5, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Slice the top edge adhesive: step 5, image 2 of 2
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge of the phone to slice the rear glass adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Redmi Note 7 Screen Replacement, Slice the righthand-side adhesive: step 6, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Slice the righthand-side adhesive: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right edge to slice the remaining adhesive.
      • Don't try to remove the rear glass all the way yet. The fingerprint sensor is still connected to the motherboard.
      Ask FixBot
    7. Xiaomi Redmi Note 7 Screen Replacement, Open up the phone assembly: step 7, image 1 of 3 Xiaomi Redmi Note 7 Screen Replacement, Open up the phone assembly: step 7, image 2 of 3 Xiaomi Redmi Note 7 Screen Replacement, Open up the phone assembly: step 7, image 3 of 3
      • Carefully fold the rear glass to the left side of the phone assembly like you'd open the front cover of a book.
      • Avoid tensioning the fingerprint flex cable during this process.
      Ask FixBot
    1. Xiaomi Redmi Note 7 Screen Replacement, Unfasten the screws: step 8, image 1 of 1
      • Use a Phillips screw driver to remove the three 3.3 mm-long screws securing the connector cover to the midframe.
      Ask FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Remove the connector cover: step 9, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Remove the connector cover: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the connector cover.
      Ask FixBot
    3. Xiaomi Redmi Note 7 Screen Replacement, Disconnect the battery: step 10, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Disconnect the battery: step 10, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the battery flex cable from the motherboard.
      Ask FixBot
    1. Xiaomi Redmi Note 7 Screen Replacement, Peel the protective foil off: step 11, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Peel the protective foil off: step 11, image 2 of 2
      Buy
      • For easier handling during repairs we highly recommend to separate the back cover including the fingerprint sensor from the phone assembly.
      • Use a pair of tweezers to carefully peel the yellow protective foil off the ZIF connector.
      Ask FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Open the ZIF connector: step 12, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Open the ZIF connector: step 12, image 2 of 2
      • Use the pointed end of a spudger to open the ZIF connector by bringing its black flap in an upright position.
      Ask FixBot
    3. Xiaomi Redmi Note 7 Screen Replacement, Disconnect the fingerprint flex cable: step 13, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Disconnect the fingerprint flex cable: step 13, image 2 of 2
      • Disconnect the fingerprint flex cable by pulling it straight out off the ZIF connector using a pair of tweezers.
      Ask FixBot
    1. Xiaomi Redmi Note 7 Screen Replacement, Unfasten the screws: step 14, image 1 of 1
      • Use a Phillips screw driver to remove the eight 3.3 mm-long screws securing the loudspeaker assembly.
      Ask FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Remove the loudspeaker assembly: step 15, image 1 of 3 Xiaomi Redmi Note 7 Screen Replacement, Remove the loudspeaker assembly: step 15, image 2 of 3 Xiaomi Redmi Note 7 Screen Replacement, Remove the loudspeaker assembly: step 15, image 3 of 3
      • Slide an opening pick underneath the right edge of the loudspeaker assembly.
      • Use the opening pick to pry up the loudspeaker assembly.
      • Remove the loudspeaker assembly.
      Ask FixBot
    1. Xiaomi Redmi Note 7 Screen Replacement, Unfasten the display connector cover screw: step 16, image 1 of 1
      • Use a Phillips screw driver to remove the 3.3 mm-long screw securing the display connector cover to the midframe.
      Ask FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Remove the display connector cover: step 17, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Remove the display connector cover: step 17, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the display connector cover.
      Ask FixBot
    3. Xiaomi Redmi Note 7 Screen Replacement, Disconnect the display flex cable: step 18, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Disconnect the display flex cable: step 18, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the display flex cable.
      Ask FixBot
    4. Xiaomi Redmi Note 7 Screen Replacement, Loosen the display adhesive: step 19, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Loosen the display adhesive: step 19, image 2 of 2
      • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Ask FixBot
    5. Xiaomi Redmi Note 7 Screen Replacement, Insert an iFlex: step 20, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Insert an iFlex: step 20, image 2 of 2
      • Once the screen is warm to touch, apply a suction cup to the bottom edge of the phone.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert the tip of an iFlex in the gap between the midframe and the screen.
      Ask FixBot
    6. Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: step 21, image 1 of 3 Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: step 21, image 2 of 3 Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: step 21, image 3 of 3
      • Insert the tip of an opening pick in the gap between the midframe and the screen, next to the iFlex.
      • Remove the iFlex.
      • Slide the opening pick to the bottom right corner to cut the adhesive. Leave it in its place to prevent the adhesive from resealing.
      Ask FixBot
    7. Xiaomi Redmi Note 7 Screen Replacement, Cut the adhesive: step 22, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Cut the adhesive: step 22, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
      Ask FixBot
    8. Xiaomi Redmi Note 7 Screen Replacement, Cut the lefthand-side adhesive: step 23, image 1 of 3 Xiaomi Redmi Note 7 Screen Replacement, Cut the lefthand-side adhesive: step 23, image 2 of 3 Xiaomi Redmi Note 7 Screen Replacement, Cut the lefthand-side adhesive: step 23, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun to reheat it.
      • Insert a third opening pick under the bottom left corner of the phone.
      • Slide the opening pick up to the top left corner to cut the adhesive. Leave it in to prevent the adhesive from resealing.
      Ask FixBot
    9. Xiaomi Redmi Note 7 Screen Replacement, Cut the top edge adhesive: step 24, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Cut the top edge adhesive: step 24, image 2 of 2
      • Insert a fourth opening pick at the top left corner.
      • Slide the opening pick along the top edge of the phone to cut the adhesive. Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
      • When you slice near the front facing camera, insert only the tip of the opening pick to avoid damaging or smearing the camera.
      Ask FixBot
    10. Xiaomi Redmi Note 7 Screen Replacement, Cut the righthand-side adhesive: step 25, image 1 of 2 Xiaomi Redmi Note 7 Screen Replacement, Cut the righthand-side adhesive: step 25, image 2 of 2
      • Insert a fifth opening pick and slide it along the right edge of the phone to cut the remaining adhesive.
      • Do not try to remove the display all the way yet, the display cable is still threaded through the frame and possibly adhered on the inner side of the midframe.
      Ask FixBot
    11. Xiaomi Redmi Note 7 Screen Replacement, Remove the screen: step 26, image 1 of 3 Xiaomi Redmi Note 7 Screen Replacement, Remove the screen: step 26, image 2 of 3 Xiaomi Redmi Note 7 Screen Replacement, Remove the screen: step 26, image 3 of 3
      • Thread the display flex cable through the gap in the midframe and remove the screen.
      • The upper speaker grill of the Redmi Note 7 is likely to fall off during this procedure. Avoid loosing it during the screen removal.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
16 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,208 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
3 Guide Comments
This guide is just WRONG and useless.
He disconnect the battery cable and nothing else: if you try this, at step 18 you will just pull a flex cable that is still screwed. The correct ribbon is not the one near the battery connector shown in step 10, but the one on the left under the camera.
Guide shows he removes 3 screews, and these are just to disconnect the battery. After this, it is necessary to remove more screws and actually disconnect the display flex: 1 to free the small metal cover blocking the ribbon (similar to step 9) and 8 more screws on the bottom of the phone to free and remove the loudspeaker, which otherwise will block the display ribbon even if it was disconnected and the first screw I mentioned removed.
A M - Reply Share
Hi A M,
thank you for your feedback. You're completely right. Some prereq guides for the screen guide were set to private and because of that not visible. I made them public and the full display removal procedure should be correct now. If you notice anything else that is wrong or I missed something, please let me know.
Dominik Schnabelrauch - Reply Share
شكراً جزيلا
Moawia Boutara - Reply Share
Past 24 Hours: 7
Past 7 Days: 51
Past 30 Days: 283
All Time: 24,284
