Introduction
Use this guide to replace or remove the motherboard in your Xiaomi Redmi Note 3.
Before disassembling your device, be sure the battery is charged below 25%. If accidentally punctured or damaged, the battery can catch fire and/or explode; if discharged below 25%, the chances of fire/explosion is decreased.
Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the phone's top edge.
Press gently to eject the SIM tray
Remove the SIM card tray from the device.
Insert the flat end of a spudger under the assembly at the bottom of the device near the right-hand corner.
Pry upwards with the spudger to release the right-hand corner of the assembly.
Insert the flat end of a spudger under the assembly at the bottom of the device near the left-hand corner.
Pry upwards with the spudger to release the left-hand corner of the assembly.
Use your fingers to remove the assembly.
