Up to 20% off select tools
Xiaomi Redmi Note 3 Disassembly Guide
Views: 2.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
139
All Time:
2,449
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This is a guide for the disassembly of the Xiaomi Redmi Note 3.
While not necessary, to complete this disassembly, folks are encouraged to have basic knowledge on the workings of phone electronics.
    1. Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: step 1, image 1 of 2 Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: step 1, image 2 of 2
      • Locate the sim card tray at the right side of the phone
      • Insert the metal needle sim tool into the tray hole to eject the tray and pull it out
      Ask FixBot
    2. Xiaomi Redmi Note 3 Disassembly Guide, Remove Phone Panel: step 2, image 1 of 1
      • Insert your thumb in between the back panel and the front of phone and slowly follow along the edges to separate the two pieces
      Ask FixBot
    3. Xiaomi Redmi Note 3 Disassembly Guide, Disconnect the Connector: step 3, image 1 of 1
      • Remove the plastic connector that links the battery with the motherboard by gently prying the ends of the connector from each side of the phone
      Ask FixBot
    4. Xiaomi Redmi Note 3 Disassembly Guide, Begin Battery Removal: step 4, image 1 of 1
      • Pull the black tab at the top left of the battery to disconnect the battery from the system
      Ask FixBot
    5. Xiaomi Redmi Note 3 Disassembly Guide, Remove Battery: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Wedge the tweezers under the battery to lift it up
      • Remove as much as adhesive as needed to lift the battery from phone using tweezers or fingers
      • Adhesive that binds the battery to the phone can be strong and this may require a little bit of effort to remove the battery
      Ask FixBot
    6. Xiaomi Redmi Note 3 Disassembly Guide, Unscrew Speaker: step 6, image 1 of 1
      • Use the screwdriver to unscrew the speaker at the bottom back of the phone. There are five screws around the edges of the speaker
      Ask FixBot
    7. Xiaomi Redmi Note 3 Disassembly Guide, Detach Speaker: step 7, image 1 of 1
      • Remove the loud speaker cover using the tweezers to expose the daughterboard
      Ask FixBot
    8. Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: step 8, image 1 of 2 Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: step 8, image 2 of 2
      • Remove the two gold tabs on the two top corners of the daughterboard
      • Pry the daughterboard open with the tweezers or pull it out using your fingers
      • There is a heat shield underneath the daughter board and it can get hot from charging the phone so make sure you don’t touch it
      Ask FixBot
    9. Xiaomi Redmi Note 3 Disassembly Guide, Begin to Remove Camera: step 9, image 1 of 1
      • Unscrew the four screws at the top of the motherboard and pop up the top cover
      • One screw might by disguised by a sticker so locate that and remove the sticker as well
      • Pulling the top cover without removing all the screws might damage the motherboard
      Ask FixBot
    10. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera Cushion: step 10, image 1 of 1
      • Remove the rubber cover that’s containing the camera
      Ask FixBot
    11. Xiaomi Redmi Note 3 Disassembly Guide, Remove Front Camera Protector: step 11, image 1 of 1
      • Pull the tab that’s holding the front camera to remove the camera protector
      • To keep the camera from damage hold the camera from the corner and not from the middle of it
      Ask FixBot
    12. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera: step 12, image 1 of 1
      • Pull out the front camera using tweezers or your fingers
      Ask FixBot
    13. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard Connectors: step 13, image 1 of 1
      • Remove the five connectors of the motherboard using tweezers or your fingers
      Ask FixBot
    14. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard: step 14, image 1 of 1
      • Remove the remaining four screws as your work down to the bottom to loosen the motherboard
      Ask FixBot
    15. Xiaomi Redmi Note 3 Disassembly Guide, Admire Disassembled Phone: step 15, image 1 of 1
      • Congrats -- You disassembled the Xiaomi Redmi Note 3!
      Ask FixBot
Author
with
Meaghan Owens
241 Reputation
1 Guide authored
1 Guide Comment
Memory ic problem
Sure - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 139
All Time: 2,449
