Tools
Introduction
Go to step 1 ↓If the camera module of your Xiaomi Redmi Note 13 Pro Plus 5G (Models 23090RA98C, 23090RA98G, 23090RA98I) is broken or not working properly, you might want to replace it. Common signs of a damaged camera include: abnormal noise, shaking or rattling when capturing a photo or a video, and not focusing properly.
The rear camera module is made up of 4 cameras : the front camera, the main camera, the wide angle camera and the macro camera. The main difference between these cameras is the resolution. The front camera is the camera located on the mobile screen of the phone, facing the user. It is mainly used for taking selfies and for facial recognition purposes. The main camera is the standard camera used for taking photos and videos. The wide angle camera is used for taking wide angle shots, while the macro camera is used for taking close-up shots.
This guide will walk you through the removal of the rear camera module of your Xiaomi Redmi Note 13 Pro Plus 5G. You will need to use an iOpener to remove the phone's back panel by melting the adhesive that keeps it shut.
Disconnect the device from all external power sources before disassembling.
Place the suction handle on the back panel of the phone.
While lifting the suction handle, insert the opening tool in the space created by the pulling. Try to widen the space between the back panel and the rest of the phone.
When that space is wide enough, insert at least two opening picks.
Remove the seven 5.2 mm black motherboard cover screws using a JIS #000 screwdriver.
Remove the three 4.4 mm grey motherboard-cover screws using a JIS #000 screwdriver.
Using the picks, remove the motherboard cover. The black strip covering the battery should be attached to the motherboard cover and removed at the same time.
Lift up the two ribbons holding the battery.
Remove the eight 5.3 mm black ringer-cover screws using a JIS #000 screwdriver.
Remove the 4.5 mm grey ringer-screw using a JIS #000 screwdriver.
Using the opening tool, carefully remove the ringer-cover and the blue wire attached to it.
Disconnect the blue wire by unclipping the metal head of the wire.
This is the main camera.
This is the front camera.
This is the wide angle camera
This is the macro camera.
