Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement
    1. Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement, Back Panel: step 1, image 1 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement, Back Panel: step 1, image 2 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement, Back Panel: step 1, image 3 of 3
      • Remove the SIM card tray using a SIM card eject tool.
      • Make sure the device is turned off.
      Ask FixBot
    2. Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 2, image 1 of 1
      • Heat the iOpener up, then place it on every edge of the phone so the glue underneath the back panel melts.
      Ask FixBot
    3. Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 3, image 1 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 3, image 2 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 3, image 3 of 3
      • Place the suction handle on the back panel of the phone.
      • While lifting the suction handle, insert the opening tool in the space created by the pulling. Try to widen the space between the back panel and the rest of the phone.
      • When that space is wide enough, insert at least two opening picks.
      Ask FixBot
    4. Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 4, image 1 of 2 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 4, image 2 of 2
      • Drag the opening picks along the borders of the back panel to lift it up.
      • The back panel should pop out. Remove it.
      Ask FixBot
    1. Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement, Battery: step 5, image 1 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement, Battery: step 5, image 2 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement, Battery: step 5, image 3 of 3
      • Remove the seven 5.2 mm black motherboard cover screws using a JIS #000 screwdriver.
      • Remove the three 4.4 mm grey motherboard-cover screws using a JIS #000 screwdriver.
      • One screw might be covered by a red warranty sticker.
      • Using the picks, remove the motherboard cover. The black strip covering the battery should be attached to the motherboard cover and removed at the same time.
      • Lift up the two ribbons holding the battery.
      Ask FixBot
    2. Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 6, image 1 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 6, image 2 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 6, image 3 of 3
      • Remove the eight 5.3 mm black ringer-cover screws using a JIS #000 screwdriver.
      • Remove the 4.5 mm grey ringer-screw using a JIS #000 screwdriver.
      • Using the opening tool, carefully remove the ringer-cover and the blue wire attached to it.
      • Disconnect the blue wire by unclipping the metal head of the wire.
      Ask FixBot
    3. Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 7, image 1 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 7, image 2 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 7, image 3 of 3
      • Lift up the two press connectors above the battery using an opening tool.
      • Peel off the stickers on either side of the battery.
      • Notice the orange sticker on the right side. It should be separated into two stickers labelled A and B.
      • Pull on the "A" orange sticker to prop up the battery.
      • You can use the opening tool to help prop up the battery if the sticker rips or if pulling on the sticker alone doesn't work.
      Ask FixBot
    4. Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 8, image 1 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 8, image 2 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Battery Replacement: step 8, image 3 of 3
      • Remove the battery.
      • Peel the sticker by pulling on the "B" orange sticker.
      Ask FixBot
Thanks for following this guide, we hope it helped! To reassemble your device, you can follow these instructions in reverse order.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 30
Past 7 Days: 163
Past 30 Days: 665
All Time: 1,454
