Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement
    1. Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement, Back Panel: step 1, image 1 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement, Back Panel: step 1, image 2 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • Remove the SIM card tray using a SIM card eject tool.
      • Make sure the device is turned off.
      Ask FixBot
    2. Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement: step 2, image 1 of 1
      • Heat the iOpener up, then place it on every edge of the phone so the glue underneath the back panel melts.
      Ask FixBot
    3. Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement: step 3, image 1 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement: step 3, image 2 of 3 Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement: step 3, image 3 of 3
      • Place the suction handle on the back panel of the phone.
      • While lifting the suction handle, insert the opening tool in the space created by the pulling. Try to widen the space between the back panel and the rest of the phone.
      • When that space is wide enough, insert at least two opening picks.
      Ask FixBot
    4. Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement: step 4, image 1 of 2 Xiaomi Redmi Note 13 Pro Plus 5G Back Panel Replacement: step 4, image 2 of 2
      • Drag the opening picks along the borders of the back panel to lift it up.
      • The back panel should pop out. Remove it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 50
Past 30 Days: 235
All Time: 907
