Xiaomi Redmi Note 10 Pro Battery Replacement
    1. Xiaomi Redmi Note 10 Pro Battery Replacement, Eject the SIM card tray: step 1, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Eject the SIM card tray: step 1, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Eject the SIM card tray: step 1, image 3 of 3
      • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
      • Press directly into the hole to eject the SIM card tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. Xiaomi Redmi Note 10 Pro Battery Replacement, Heat the rear glass: step 2, image 1 of 1
      • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Xiaomi Redmi Note 10 Pro Battery Replacement, Secure a suction handle: step 3, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Secure a suction handle: step 3, image 2 of 2
      • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • The surface of the rear glass is not completely smooth. For a better grip of the suction handle, apply tape to the rear glass or moisten the suction handle.
      • Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
      Ask FixBot
    3. Xiaomi Redmi Note 10 Pro Battery Replacement, Create a gap: step 4, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Create a gap: step 4, image 2 of 2
      • Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      Ask FixBot
    4. Xiaomi Redmi Note 10 Pro Battery Replacement, Slice the adhesive: step 5, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Slice the adhesive: step 5, image 2 of 2
      • Slide the opening pick to the top right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Redmi Note 10 Pro Battery Replacement, Slice the adhesive: step 6, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Slice the adhesive: step 6, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Slice the adhesive: step 6, image 3 of 3
      • Insert a second opening pick next to the top right corner.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Redmi Note 10 Pro Battery Replacement, Slice the adhesive: step 7, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Slice the adhesive: step 7, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Slice the adhesive: step 7, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom right corner of your phone.
      • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Xiaomi Redmi Note 10 Pro Battery Replacement: step 8, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement: step 8, image 2 of 2
      • Insert a fourth opening pick underneath the bottom left corner of your phone.
      • Slide the opening pick up to the volume button.
      • Don't slide the opening pick any further! A flex cable runs next to the volume button.
      Ask FixBot
    8. Xiaomi Redmi Note 10 Pro Battery Replacement: step 9, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement: step 9, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement: step 9, image 3 of 3
      • Insert a sixth opening pick at the left edge of your phone next to the top end of the power and volume button cut out.
      • Slice the remaining adhesive of the left edge.
      • Slide the opening pick around the top left corner and along the top edge to cut the remaining adhesive.
      Ask FixBot
    9. Xiaomi Redmi Note 10 Pro Battery Replacement, Remove the rear glass: step 10, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Remove the rear glass: step 10, image 2 of 2
      • Remove the rear glass.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Xiaomi Redmi Note 10 Pro Battery Replacement, Unscrew the midframe: step 11, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Unscrew the midframe: step 11, image 2 of 2
      • Use a Phillips screwdriver to remove the seventeen screws securing the midframe:
      • Nine 4.4 mm-long screws in the upper area of the midframe
      • Eight 3.4 mm-long screws in the lower area of the midframe
      Ask FixBot
    2. Xiaomi Redmi Note 10 Pro Battery Replacement, Insert an opening pick: step 12, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Insert an opening pick: step 12, image 2 of 2
      • The midframe is held in place by plastic clips.
      • Insert an opening pick between the midframe and front panel assembly on the bottom of the phone near the charging port.
      • Slide the opening pick to the bottom left corner to release the plastic clips.
      Ask FixBot
    3. Xiaomi Redmi Note 10 Pro Battery Replacement, Release the plastic clips: step 13, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Release the plastic clips: step 13, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Release the plastic clips: step 13, image 3 of 3
      • Slide the opening pick along the left edge of your phone to release the plastic clips.
      Ask FixBot
    4. Xiaomi Redmi Note 10 Pro Battery Replacement: step 14, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement: step 14, image 2 of 2
      • Slide the opening pick along the top edge to release the plastic clips.
      Ask FixBot
    5. Xiaomi Redmi Note 10 Pro Battery Replacement: step 15, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement: step 15, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement: step 15, image 3 of 3
      • Slide the opening pick along the right edge to release the remaining plastic clips.
      • Don't try to remove the midframe all the way yet! The side buttons are still connected to the motherboard by a flex cable.
      Ask FixBot
    6. Xiaomi Redmi Note 10 Pro Battery Replacement, Swing open the midframe: step 16, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Swing open the midframe: step 16, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Swing open the midframe: step 16, image 3 of 3
      • Avoid straining the side button flex cable in the following step!
      • Carefully swing the midframe open in the direction of the power and volume buttons and place the midframe close to the phone assembly.
      Ask FixBot
    7. Xiaomi Redmi Note 10 Pro Battery Replacement, Disconnect the power and volume button flex cable: step 17, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Disconnect the power and volume button flex cable: step 17, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the power and volume button flex cable from the motherboard.
      Ask FixBot
    8. Xiaomi Redmi Note 10 Pro Battery Replacement, Remove the midframe: step 18, image 1 of 1
      • Remove the midframe.
      Ask FixBot
    1. Xiaomi Redmi Note 10 Pro Battery Replacement, Disconnect the battery cable: step 19, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Disconnect the battery cable: step 19, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    1. Xiaomi Redmi Note 10 Pro Battery Replacement, Remove the black graphite film: step 20, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Remove the black graphite film: step 20, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Remove the black graphite film: step 20, image 3 of 3
      • Carefully slide an opening pick underneath the graphite film covering the battery and the loudspeaker assembly to loosen its adhesive.
      • Remove the graphite film.
      Ask FixBot
    2. Xiaomi Redmi Note 10 Pro Battery Replacement, Peel the pull tabs off the battery: step 21, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Peel the pull tabs off the battery: step 21, image 2 of 2
      Tool used on this step:
      Buy
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labeled with a A off the battery.
      • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labeled with a B off the battery.
      Ask FixBot
    3. Xiaomi Redmi Note 10 Pro Battery Replacement, Lift the battery out of its recess: step 22, image 1 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Lift the battery out of its recess: step 22, image 2 of 3 Xiaomi Redmi Note 10 Pro Battery Replacement, Lift the battery out of its recess: step 22, image 3 of 3
      • Pull up on the orange adhesive strip labeled with the A to lift the battery out of its recess and swing it up to an upright position.
      • Although these adhesive tabs are supposed to make the battery removal easier, they may require some force. In case you're having trouble removing the battery, you can apply a heated iOpener to the center of the display to loosen the adhesive underneath.
      Ask FixBot
    4. Xiaomi Redmi Note 10 Pro Battery Replacement, Remove the battery: step 23, image 1 of 1
      • Peel the battery off the remaining adhesive.
      • Remove the battery.
      • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated
      Ask FixBot
    5. Xiaomi Redmi Note 10 Pro Battery Replacement, Peel off the remaining adhesive: step 24, image 1 of 2 Xiaomi Redmi Note 10 Pro Battery Replacement, Peel off the remaining adhesive: step 24, image 2 of 2
      • Peel the battery's adhesive sticker off the midframe.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
51 other people completed this guide.
Adriana Zwink
69,148 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
12 Guide Comments
I noticed that both in your tutorial and in my device, the original battery compatible with the Redmi Note 10 Pro is the Model BN53. However, when I search for replacement batteries, the BN53 is not compatible with the cell phone, and they indicate the BN59. Could you tell me why?
gabriel.grift - Reply Share
Donde puedo conseguir esa bateria en España
manuel morales garcia - Reply Share
The battery sold here as a replacement for the Redmi Note 10 PRO is slightly shorter than the original one, no idea why. Furthermore, on the original one, there's a piece of plastic over the circuit which is missing on this one. Anyway, it's possible to swap it over as I did, although you'll never apply the tape as it was originally, assuming you're being a perfectionist. On that note, it's unlikely you'll close the phone to look as it did originally either. The whole process of battery replacing is more of a last, desperate measure opposed to something that was meant to be done reliably, obviously. This is further supported by the fact that any replacement battery you'll find, is ultimately an aftermarket one. The original ones are only produced for the manufacturer. I'll have to see now how this one is going to behave.
Albert - Reply Share
hello Albert , did you buy the bn53 one from here? and if it was shorter than the original, how did you solve it?
Chowdhury - Reply Share
Hello, Chowdhury. Yes, I bought the battery from here.
U don't have to do anything about it being a few millimetres shorter since it still fits firmly width-wise so there's no wobbling or anything.
As for the battery's performance, it's definitely better than the original, old battery so still worth the effort should one want to continue using their old phone.
Past 24 Hours: 32
Past 7 Days: 265
Past 30 Days: 1,321
All Time: 58,824
