Xiaomi Redmi Note 10 5G Screen Replacement
    1. Xiaomi Redmi Note 10 5G Screen Replacement, Heat the back cover: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Xiaomi Redmi Note 10 5G Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Xiaomi Redmi Note 10 5G Screen Replacement, Slice the adhesive: step 3, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Xiaomi Redmi Note 10 5G Screen Replacement, Slice the adhesive: step 4, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Slice the adhesive: step 4, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Slice the adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Redmi Note 10 5G Screen Replacement: step 5, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement: step 5, image 2 of 2
      • Insert a fourth opening pick underneath the top left corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Redmi Note 10 5G Screen Replacement: step 6, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
      Ask FixBot
    7. Xiaomi Redmi Note 10 5G Screen Replacement, Remove the back cover: step 7, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the back cover: step 7, image 2 of 2
      • Remove the back cover.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Xiaomi Redmi Note 10 5G Screen Replacement, Unfasten the camera cover screws: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the camera cover.
      Ask FixBot
    2. Xiaomi Redmi Note 10 5G Screen Replacement, Pry up the camera cover: step 9, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Pry up the camera cover: step 9, image 2 of 2
      • Insert an opening pick into the gap between the left edge of the camera cover and the midframe.
      • Use your opening pick to pry up the camera cover by tilting it downwards.
      Ask FixBot
    3. Xiaomi Redmi Note 10 5G Screen Replacement, Remove the camera cover: step 10, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the camera cover: step 10, image 2 of 2
      • Remove the camera cover.
      Ask FixBot
    4. Xiaomi Redmi Note 10 5G Screen Replacement, Unfasten the midframe screws: step 11, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Unfasten the midframe screws: step 11, image 2 of 2
      • Use a Phillips screwdriver to remove the thirteen 3.9 mm-long screws securing the midframe.
      Ask FixBot
    5. Xiaomi Redmi Note 10 5G Screen Replacement, Eject the SIM card tray: step 12, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Eject the SIM card tray: step 12, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Eject the SIM card tray: step 12, image 3 of 3
      • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
      • Press directly into the hole to eject the SIM card tray.
      • Remove the SIM card tray.
      Ask FixBot
    6. Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the power and volume button flex cable: step 13, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the power and volume button flex cable: step 13, image 2 of 2
      • Use a spudger to disconnect the power and volume button flex cable by prying the connector straight up from its socket.
      Ask FixBot
    7. Xiaomi Redmi Note 10 5G Screen Replacement, Insert an opening pick: step 14, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Insert an opening pick: step 14, image 2 of 2
      • The midframe of the Xiaomi Redmi Note 10 5G is held in place by plastic clips.
      • Insert an opening pick between the midframe and front panel assembly on the left edge of the phone where the SIM tray slot is located.
      Ask FixBot
    8. Xiaomi Redmi Note 10 5G Screen Replacement, Release the plastic clips: step 15, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Release the plastic clips: step 15, image 2 of 2
      • The plastic clips of the midframe are sitting in place tightly. Releasing them might require some force.
      • Slide the opening pick along the left edge of the phone to release the plastic clips.
      Ask FixBot
    9. Xiaomi Redmi Note 10 5G Screen Replacement: step 16, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement: step 16, image 2 of 2
      • Slide the opening pick along the bottom edge of the phone to release the plastic clips.
      Ask FixBot
    10. Xiaomi Redmi Note 10 5G Screen Replacement: step 17, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement: step 17, image 2 of 2
      • Slide the opening pick along the right edge of the phone to release the plastic clips.
      Ask FixBot
    11. Xiaomi Redmi Note 10 5G Screen Replacement: step 18, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement: step 18, image 2 of 2
      • Slide the opening pick along the top edge of the phone to release the remaining plastic clips.
      Ask FixBot
    12. Xiaomi Redmi Note 10 5G Screen Replacement, Remove the midframe: step 19, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the midframe: step 19, image 2 of 2
      • Before removing the midframe make sure the power and volume button flex cable is freed and not tangled with the motherboard to avoid tearing it.
      • Remove the midframe.
      Ask FixBot
    1. Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the battery cable: step 20, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the battery cable: step 20, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the battery cable: step 20, image 3 of 3
      • Use a spudger to disconnect the battery flex cable by prying the connector straight up from its socket.
      • Fold the battery cable to the side to get free access to the battery pull-tab.
      Ask FixBot
    1. Xiaomi Redmi Note 10 5G Screen Replacement, Remove the stretch-release adhesive: step 21, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the stretch-release adhesive: step 21, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the stretch-release adhesive: step 21, image 3 of 3
      Tool used on this step:
      Buy
      • The battery is secured to the rear case with two pieces of stretch-release adhesive.
      • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
      • Use a pair of blunt nose tweezers or a clean fingernail to peel up both battery adhesive pull-tabs to unstick them from the top edge of the battery.
      Ask FixBot
    2. Xiaomi Redmi Note 10 5G Screen Replacement, Remove the pull-tabs: step 22, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the pull-tabs: step 22, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the pull-tabs: step 22, image 3 of 3
      • Grab the first pull-tab with a pair of blunt nose tweezers or your fingers and slowly pull it away from the battery towards the top edge of your phone.
      • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and unstick from under the battery.
      • Don't press down on the battery. Hold the phone firmly by its sides.
      • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling in the middle or on one side.
      • Pull at a low angle so the strip doesn't snag on the edge of the battery.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
      • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
      Ask FixBot
    3. Xiaomi Redmi Note 10 5G Screen Replacement: step 23, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement: step 23, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement: step 23, image 3 of 3
      • Repeat the previous pull-tab removal procedure on the second pull-tab.
      • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
      • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
      • Wait about one minute for the alcohol solution to weaken the adhesive.
      • Use the flat end of a spudger to gently lift the battery.
      • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      Ask FixBot
    4. Xiaomi Redmi Note 10 5G Screen Replacement, Remove the battery: step 24, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the battery: step 24, image 2 of 2
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
      Ask FixBot
    1. Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the display flex cable: step 25, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the display flex cable: step 25, image 2 of 2
      • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
      Ask FixBot
    2. Xiaomi Redmi Note 10 5G Screen Replacement, Free the display flex cable: step 26, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Free the display flex cable: step 26, image 2 of 2
      • The display flex cable is adhered to the front panel assembly by mild adhesive.
      • Carefully slide an opening pick underneath the display flex cable to separate it from the front panel assembly.
      Ask FixBot
    3. Xiaomi Redmi Note 10 5G Screen Replacement, Remove the loudspeaker: step 27, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the loudspeaker: step 27, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Remove the loudspeaker: step 27, image 3 of 3
      • Insert an opening pick into the gap between the front panel assembly and the loudspeaker at the top edge of the speaker.
      • Twist the opening pick sideways to pry up the loudspeaker.
      • Remove the loudspeaker.
      Ask FixBot
    4. Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the digitizer flex cable: step 28, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Disconnect the digitizer flex cable: step 28, image 2 of 2
      • Use a spudger to disconnect the digitizer flex cable by prying the connector straight up from its socket.
      Ask FixBot
    5. Xiaomi Redmi Note 10 5G Screen Replacement, Loosen the display adhesive: step 29, image 1 of 1
      • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      • The adhesive of the Redmi Note 10 5G is very strong and it's hard to get underneath the display panel in the beginning. It is likely that you will have to reapply the iOpener more than once.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Ask FixBot
    6. Xiaomi Redmi Note 10 5G Screen Replacement, Insert an iFlex: step 30, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Insert an iFlex: step 30, image 2 of 2
      • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an iFlex into the gap between the midframe and the screen.
      Ask FixBot
    7. Xiaomi Redmi Note 10 5G Screen Replacement, Insert an opening pick: step 31, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Insert an opening pick: step 31, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Insert an opening pick: step 31, image 3 of 3
      • Insert an opening pick above the iFlex.
      • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
      Ask FixBot
    8. Xiaomi Redmi Note 10 5G Screen Replacement, Slice the adhesive: step 32, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement, Slice the adhesive: step 32, image 2 of 2
      • Remove the iFlex.
      • Insert a second opening pick at the bottom right corner and slide it to the bottom left corner of the screen to slice the adhesive.
      Ask FixBot
    9. Xiaomi Redmi Note 10 5G Screen Replacement: step 33, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement: step 33, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement: step 33, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
      • Insert a third opening pick underneath the bottom left corner of the screen.
      • Slide the opening pick along the left edge of the screen to slice the adhesive.
      • Leave it in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    10. Xiaomi Redmi Note 10 5G Screen Replacement: step 34, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement: step 34, image 2 of 2
      • When you slice near the front facing camera, insert only the tip of the opening pick (about 2-3 mm) to avoid damaging or smearing the camera.
      • Insert a fourth opening pick at the top left corner of the screen.
      • Slide the opening pick along the top edge of the phone to slice the adhesive.
      Ask FixBot
    11. Xiaomi Redmi Note 10 5G Screen Replacement: step 35, image 1 of 2 Xiaomi Redmi Note 10 5G Screen Replacement: step 35, image 2 of 2
      • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
      • Do not try to remove the display all the way yet, the display and the digitizer cable are still threaded through the front panel assembly.
      Ask FixBot
    12. Xiaomi Redmi Note 10 5G Screen Replacement, Free the display cables: step 36, image 1 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Free the display cables: step 36, image 2 of 3 Xiaomi Redmi Note 10 5G Screen Replacement, Free the display cables: step 36, image 3 of 3
      • Thread the digitizer flex cable through the gap in the front panel assembly.
      • Thread the display flex cable through the gap in the front panel assembly.
      Ask FixBot
    13. Xiaomi Redmi Note 10 5G Screen Replacement, Remove the screen: step 37, image 1 of 1
      • Remove the screen.
      • Compare your new replacement part to the original part—you may need to transfer remaining components from your old screen to your replacement part.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
15 other people completed this guide.
Dominik Schnabelrauch
266,149 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,871 Guides authored
4 Guide Comments
Hi
I just did this and I had an issue with "don't cover earphone area". I realize that I can solve this by just switching off pocket mode but, that's a handy feature.
When I replaced the screen I had to use double sided sicky tape to stick the screen to the frame, can anyone tell me where the sensor is located, I intend to open it again and replace the double sided tape with phone adhesive.
Otherwise, super handy guide, thanks! Love this site for repairs. Complete, thorough, and the way every step is photographed and labelled.
Jazz Wood - Reply Share
Impeccable.
J'ai suivi de l'étape 1 à l'étape 37, tout s'est parfaitement déroulé, j'ai un écran tout neuf posé pour 0€ ( Sauf 20€ d'achat d'écran )
Merci
Nico C - Reply Share
Thanks. Nice guide, well detailed.
Alain Madelin - Reply Share
Impeccable,
Malgré plusieurs vidéos sur YT, j'ai préféré voir ce tuto alors que je n'aime pas les tutos photos!!
Ça en dit long sur la qualité du tuto.
Juste un truc, j'ai le message qui dit que je doit pas caché le capteur de proximité alors qu'il n'y a rien. Je pense avoir oublié d'enlever un cache ou mal fixé le dit capteur.
Néanmoins, j'ai désactive dans les paramètres, puis dans écran de verrouillage (et non pas empreinte digitale, données faciale et verrouillage écran)le mode poche pour ne plus avoir le message.
Flemme de devoir re démonter !
Merci beaucoup
Oran Odesespoir - Reply Share
Past 24 Hours: 7
Past 7 Days: 57
Past 30 Days: 354
All Time: 25,213
