Xiaomi Redmi Note 10 5G Back Cover Replacement
Views: 7.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
127
All Time:
7,262
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove or replace a damaged back cover on your Xiaomi Redmi Note 10 5G.
You’ll need replacement adhesive to reattach components when reassembling the device.
Parts
Tools
    1. Xiaomi Redmi Note 10 5G Back Cover Replacement, Heat the back cover: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Xiaomi Redmi Note 10 5G Back Cover Replacement, Insert an opening pick: step 2, image 1 of 3 Xiaomi Redmi Note 10 5G Back Cover Replacement, Insert an opening pick: step 2, image 2 of 3 Xiaomi Redmi Note 10 5G Back Cover Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Xiaomi Redmi Note 10 5G Back Cover Replacement, Slice the adhesive: step 3, image 1 of 2 Xiaomi Redmi Note 10 5G Back Cover Replacement, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Xiaomi Redmi Note 10 5G Back Cover Replacement, Slice the adhesive: step 4, image 1 of 3 Xiaomi Redmi Note 10 5G Back Cover Replacement, Slice the adhesive: step 4, image 2 of 3 Xiaomi Redmi Note 10 5G Back Cover Replacement, Slice the adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Redmi Note 10 5G Back Cover Replacement: step 5, image 1 of 2 Xiaomi Redmi Note 10 5G Back Cover Replacement: step 5, image 2 of 2
      • Insert a fourth opening pick underneath the top left corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Redmi Note 10 5G Back Cover Replacement: step 6, image 1 of 2 Xiaomi Redmi Note 10 5G Back Cover Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
      Ask FixBot
    7. Xiaomi Redmi Note 10 5G Back Cover Replacement, Remove the back cover: step 7, image 1 of 2 Xiaomi Redmi Note 10 5G Back Cover Replacement, Remove the back cover: step 7, image 2 of 2
      • Remove the back cover.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
2 other people completed this guide.
Dominik Schnabelrauch
266,207 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 127
All Time: 7,262
