Xiaomi Redmi 2 Screen Assembly Replacement
    1. Xiaomi Redmi 2 Screen Assembly Replacement, Motherboard: step 1, image 1 of 2 Xiaomi Redmi 2 Screen Assembly Replacement, Motherboard: step 1, image 2 of 2
      • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
      Ask FixBot
    2. Xiaomi Redmi 2 Screen Assembly Replacement: step 2, image 1 of 1
      • Insert your finger into the curved opening of the mid-frame.
      • Lift the battery and remove.
      Ask FixBot
    3. Xiaomi Redmi 2 Screen Assembly Replacement: step 3, image 1 of 1
      • Remove the SIM and/or memory cards if present.
      • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
      Ask FixBot
    4. Xiaomi Redmi 2 Screen Assembly Replacement: step 4, image 1 of 1
      • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
      Ask FixBot
    5. Xiaomi Redmi 2 Screen Assembly Replacement: step 5, image 1 of 1
      • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
      • Keep this screw separate from the initial twelve.
      Ask FixBot
    6. Xiaomi Redmi 2 Screen Assembly Replacement: step 6, image 1 of 2 Xiaomi Redmi 2 Screen Assembly Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
      Ask FixBot
    7. Xiaomi Redmi 2 Screen Assembly Replacement: step 7, image 1 of 2 Xiaomi Redmi 2 Screen Assembly Replacement: step 7, image 2 of 2
      • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
      Ask FixBot
    8. Xiaomi Redmi 2 Screen Assembly Replacement: step 8, image 1 of 2 Xiaomi Redmi 2 Screen Assembly Replacement: step 8, image 2 of 2
      • Lift and hinge the motherboard with your fingers.
      Ask FixBot
    9. Xiaomi Redmi 2 Screen Assembly Replacement: step 9, image 1 of 2 Xiaomi Redmi 2 Screen Assembly Replacement: step 9, image 2 of 2
      • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
      Ask FixBot
    10. Xiaomi Redmi 2 Screen Assembly Replacement: step 10, image 1 of 2 Xiaomi Redmi 2 Screen Assembly Replacement: step 10, image 2 of 2
      • Using the tweezers, pull the antenna connector from the motherboard.
      Ask FixBot
    11. Xiaomi Redmi 2 Screen Assembly Replacement: step 11, image 1 of 1
      • Lift the motherboard out of the front cover and set aside.
      Ask FixBot
    1. Xiaomi Redmi 2 Screen Assembly Replacement, Front Speaker: step 12, image 1 of 1
      • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
      Ask FixBot
    2. Xiaomi Redmi 2 Screen Assembly Replacement: step 13, image 1 of 1
      • Using your fingers, gently lift the front speaker from the screen assembly.
      Ask FixBot
    1. Xiaomi Redmi 2 Screen Assembly Replacement, PCB Circuit Board: step 14, image 1 of 1
      • Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
      Ask FixBot
    2. Xiaomi Redmi 2 Screen Assembly Replacement: step 15, image 1 of 1
      Buy
      • Using the tweezers, lift the antenna connector from the PCB circuit board.
      Ask FixBot
    3. Xiaomi Redmi 2 Screen Assembly Replacement: step 16, image 1 of 2 Xiaomi Redmi 2 Screen Assembly Replacement: step 16, image 2 of 2
      • Do not remove the PCB circuit board at this time.
      • Using the nylon or metal spudger, gently pry back the top of the PCB circuit board from the screen assembly.
      Ask FixBot
    4. Xiaomi Redmi 2 Screen Assembly Replacement: step 17, image 1 of 1
      • Using the nylon or metal spudger, pry back the silver clip covering the ribbon connector.
      Ask FixBot
    5. Xiaomi Redmi 2 Screen Assembly Replacement: step 18, image 1 of 2 Xiaomi Redmi 2 Screen Assembly Replacement: step 18, image 2 of 2
      • Carefully lift the PCB circuit board from the screen assembly and set aside.
      • The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
      Ask FixBot
31 other people completed this guide.
Alicia Brenner
3,569 Reputation
5 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2015 Member of USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 Members
60 Guides authored
2 Guide Comments
ok so good is can service nice
SAFUTRA - Reply Share
Touch is not working after replacing full LCD, Brought new display & changed again but no luck, Display is okay but touch not working.
Rajesh Gopisetti - Reply Share
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 133
All Time: 18,295
