Xiaomi Redmi 2 Front Speaker Replacement
  1. Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: step 1, image 1 of 2 Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: step 1, image 2 of 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
    Ask FixBot
  2. Xiaomi Redmi 2 Front Speaker Replacement: step 2, image 1 of 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
    Ask FixBot
  3. Xiaomi Redmi 2 Front Speaker Replacement: step 3, image 1 of 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
    Ask FixBot
  4. Xiaomi Redmi 2 Front Speaker Replacement: step 4, image 1 of 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
    Ask FixBot
  5. Xiaomi Redmi 2 Front Speaker Replacement: step 5, image 1 of 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
    Ask FixBot
  6. Xiaomi Redmi 2 Front Speaker Replacement: step 6, image 1 of 2 Xiaomi Redmi 2 Front Speaker Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
    Ask FixBot
  7. Xiaomi Redmi 2 Front Speaker Replacement: step 7, image 1 of 2 Xiaomi Redmi 2 Front Speaker Replacement: step 7, image 2 of 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
    Ask FixBot
  8. Xiaomi Redmi 2 Front Speaker Replacement: step 8, image 1 of 2 Xiaomi Redmi 2 Front Speaker Replacement: step 8, image 2 of 2
    • Lift and hinge the motherboard with your fingers.
    Ask FixBot
  9. Xiaomi Redmi 2 Front Speaker Replacement: step 9, image 1 of 2 Xiaomi Redmi 2 Front Speaker Replacement: step 9, image 2 of 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
    Ask FixBot
  10. Xiaomi Redmi 2 Front Speaker Replacement: step 10, image 1 of 2 Xiaomi Redmi 2 Front Speaker Replacement: step 10, image 2 of 2
    • Using the tweezers, pull the antenna connector from the motherboard.
    Ask FixBot
  11. Xiaomi Redmi 2 Front Speaker Replacement: step 11, image 1 of 1
    • Lift the motherboard out of the front cover and set aside.
    Ask FixBot
  12. Xiaomi Redmi 2 Front Speaker Replacement, Front Speaker: step 12, image 1 of 1
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
    Ask FixBot
  13. Xiaomi Redmi 2 Front Speaker Replacement: step 13, image 1 of 1
    • Using your fingers, gently lift the front speaker from the screen assembly.
    Ask FixBot
7 other people completed this guide.
Alicia Brenner
3,569 Reputation
5 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2015 Member of USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 Members
5 Guides authored
4 Guide Comments
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
brunofichos - Reply Share
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
afreitasleonardo - Reply Share
Rademi 2 front Speakers problem
Amol Surve - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 72
All Time: 7,731
