Xiaomi Redmi 2 Ambient Light Sensor Replacement
    1. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: step 1, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: step 1, image 2 of 2
      • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
      Ask FixBot
    2. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 2, image 1 of 1
      • Insert your finger into the curved opening of the mid-frame.
      • Lift the battery and remove.
      Ask FixBot
    3. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 3, image 1 of 1
      • Remove the SIM and/or memory cards if present.
      • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
      Ask FixBot
    4. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 4, image 1 of 1
      • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
      Ask FixBot
    5. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 5, image 1 of 1
      • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
      • Keep this screw separate from the initial twelve.
      Ask FixBot
    6. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 6, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
      Ask FixBot
    7. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 7, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 7, image 2 of 2
      • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
      Ask FixBot
    8. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 8, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 8, image 2 of 2
      • Lift and hinge the motherboard with your fingers.
      Ask FixBot
    9. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 9, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 9, image 2 of 2
      • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
      Ask FixBot
    10. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 10, image 1 of 2 Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 10, image 2 of 2
      • Using the tweezers, pull the antenna connector from the motherboard.
      Ask FixBot
    11. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 11, image 1 of 1
      • Lift the motherboard out of the front cover and set aside.
      Ask FixBot
    1. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Ambient Light Sensor: step 12, image 1 of 1
      Buy
      • Using one prong of the tweezers, lift and loosen the edge of the ambient light sensor from the motherboard.
      Ask FixBot
    2. Xiaomi Redmi 2 Ambient Light Sensor Replacement: step 13, image 1 of 1
      • Using your fingers, gently pull out the ambient light sensor.
      Ask FixBot
17 other people completed this guide.
Alicia Brenner
3,569 Reputation
5 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2015 Member of USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 Members
60 Guides authored
1 Guide Comment
Thank you for giving her tips . http://www.lawumedia.com/161/daftar-harg...
Ahmad Adzan - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 59
All Time: 5,969
