Xiaomi Mi Pad Rear Case Assembly Replacement
  1. Xiaomi Mi Pad Rear Case Assembly Replacement, Rear Case Assembly: step 1, image 1 of 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
    Ask FixBot
  2. Xiaomi Mi Pad Rear Case Assembly Replacement: step 2, image 1 of 2 Xiaomi Mi Pad Rear Case Assembly Replacement: step 2, image 2 of 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
    Ask FixBot
3 other people completed this guide.
Kiefer Sivitz
572 Reputation
3 Guides authored
USF Tampa, Team 12-5, Blackwell Fall 2015 Member of USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 68
All Time: 2,197
