Up to 20% off select tools
Xiaomi Mi Note Rear camera Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
92
All Time:
5,178
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 35 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace your Xiaomi Mi Note's rear facing camera.
    1. Xiaomi Mi Note Rear camera Replacement, Battery: step 1, image 1 of 2 Xiaomi Mi Note Rear camera Replacement, Battery: step 1, image 2 of 2
      • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
      Ask FixBot
    2. Xiaomi Mi Note Rear camera Replacement: step 2, image 1 of 3 Xiaomi Mi Note Rear camera Replacement: step 2, image 2 of 3 Xiaomi Mi Note Rear camera Replacement: step 2, image 3 of 3
      • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
      • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
      • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
      • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
      Ask FixBot
    3. Xiaomi Mi Note Rear camera Replacement: step 3, image 1 of 1
      • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
      Ask FixBot
    4. Xiaomi Mi Note Rear camera Replacement: step 4, image 1 of 2 Xiaomi Mi Note Rear camera Replacement: step 4, image 2 of 2
      • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
      • Glue will be holding down the backside of the battery.
      Ask FixBot
    1. Xiaomi Mi Note Rear camera Replacement, Rear camera: step 5, image 1 of 1
      • Use a plastic spudger to detach the remaining ribbon from the motherboard.
      Ask FixBot
    2. Xiaomi Mi Note Rear camera Replacement: step 6, image 1 of 2 Xiaomi Mi Note Rear camera Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to detach the small ribbon on the left side located near the volume buttons as well as the microphone cord located on the right side along the frame.
      • When detaching the ribbon on the left use minimal force to prevent damage.
      Ask FixBot
    3. Xiaomi Mi Note Rear camera Replacement: step 7, image 1 of 2 Xiaomi Mi Note Rear camera Replacement: step 7, image 2 of 2
      • Use a tweezer to lift and remove the motherboard from the frame.
      • Be sure that the Dual SIM card and tray has been removed.
      Ask FixBot
    4. Xiaomi Mi Note Rear camera Replacement: step 8, image 1 of 1
      • Use tweezers to slide the ribbon to the right out of the insert as shown in the image.
      Ask FixBot
5 other people completed this guide.
Author
with
Abdulaziz Aldekheel
374 Reputation
2 Guides authored
USF Tampa, Team 1-6, Sullivan Fall 2015 Member of USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 Members
72 Guides authored
1 Guide Comment
With the onset of the new year, the world of smartphones is looking forward to the launch of Xiaomi Mi6, the next flagship launch in the series of Mi phones.
The Mi 5 received a lot of positive feedback when it launched last year, so we can expect that the Mi6 is going to be even better than its predecessor.
You can check out my site http://mi6splus.com/xiaomi-mi-6-features... for more info about the same.
Rick Halder - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 92
All Time: 5,178
