Up to 20% off select tools
Xiaomi Mi Note Front camera Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
96
All Time:
3,324
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace your Xiaomi Mi Note's front facing camera.
    1. Xiaomi Mi Note Front camera Replacement, Dual SIM SD Card: step 1, image 1 of 1
      • Locate the hole for the Dual SIM SD card on the left side of the phone.
      Ask FixBot
    2. Xiaomi Mi Note Front camera Replacement: step 2, image 1 of 2 Xiaomi Mi Note Front camera Replacement: step 2, image 2 of 2
      • Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
      Ask FixBot
    1. Xiaomi Mi Note Front camera Replacement, Battery: step 3, image 1 of 2 Xiaomi Mi Note Front camera Replacement, Battery: step 3, image 2 of 2
      • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
      Ask FixBot
    2. Xiaomi Mi Note Front camera Replacement: step 4, image 1 of 3 Xiaomi Mi Note Front camera Replacement: step 4, image 2 of 3 Xiaomi Mi Note Front camera Replacement: step 4, image 3 of 3
      • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
      • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
      • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
      • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
      Ask FixBot
    3. Xiaomi Mi Note Front camera Replacement: step 5, image 1 of 1
      • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
      Ask FixBot
    4. Xiaomi Mi Note Front camera Replacement: step 6, image 1 of 2 Xiaomi Mi Note Front camera Replacement: step 6, image 2 of 2
      • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
      • Glue will be holding down the backside of the battery.
      Ask FixBot
    1. Xiaomi Mi Note Front camera Replacement, Front camera: step 7, image 1 of 1
      • Use a spudger to pry upwards and detach the three ribbons that are connected to the motherboard.
      Ask FixBot
    2. Xiaomi Mi Note Front camera Replacement: step 8, image 1 of 2 Xiaomi Mi Note Front camera Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
      • You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
      • When detaching the ribbon on the left use minimal force to prevent damage.
      Ask FixBot
    3. Xiaomi Mi Note Front camera Replacement: step 9, image 1 of 2 Xiaomi Mi Note Front camera Replacement: step 9, image 2 of 2
      • Use a tweezer to lift and remove the motherboard from the frame.
      • Be sure that the Dual SIM card and tray has been removed.
      Ask FixBot
    4. Xiaomi Mi Note Front camera Replacement: step 10, image 1 of 1
      • The front camera is attached to the motherboard by a ribbon, use tweezers to detach it from the motherboard.
      Ask FixBot
4 other people completed this guide.
Author
with
Abdulaziz Aldekheel
374 Reputation
2 Guides authored
USF Tampa, Team 1-6, Sullivan Fall 2015 Member of USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 Members
72 Guides authored
1 Guide Comment
Telefonumu 2 hafta önce suya düşürdüm ilk etapta açılmadı ama şimdi açılıyor ama kamera çalışmıyor ön kamera Bir de hoparlörü boğuk çıkıyor tamir etsene
Kaan Guney - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 96
All Time: 3,324
