Xiaomi Mi Note Battery Replacement
    1. Xiaomi Mi Note Battery Replacement, Battery: step 1, image 1 of 2 Xiaomi Mi Note Battery Replacement, Battery: step 1, image 2 of 2
      • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
      Ask FixBot
    2. Xiaomi Mi Note Battery Replacement: step 2, image 1 of 3 Xiaomi Mi Note Battery Replacement: step 2, image 2 of 3 Xiaomi Mi Note Battery Replacement: step 2, image 3 of 3
      • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
      • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
      • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
      • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
      Ask FixBot
    3. Xiaomi Mi Note Battery Replacement: step 3, image 1 of 1
      • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
      Ask FixBot
    4. Xiaomi Mi Note Battery Replacement: step 4, image 1 of 2 Xiaomi Mi Note Battery Replacement: step 4, image 2 of 2
      • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
      • Glue will be holding down the backside of the battery.
      Ask FixBot
16 other people completed this guide.
Mark Sears
1,265 Reputation
4 Guides authored
USF Tampa, Team 1-6, Sullivan Fall 2015 Member of USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 69
All Time: 38,929
