Xiaomi Mi A2 Screen Replacement
    1. Xiaomi Mi A2 Screen Replacement, Screen: step 1, image 1 of 2 Xiaomi Mi A2 Screen Replacement, Screen: step 1, image 2 of 2
      • Turn off your phone before proceeding.
      • Remove SIM card tray from phone.
      • Touch something metallic to ensure you are electrostatic safe.
      Ask FixBot
    2. Xiaomi Mi A2 Screen Replacement: step 2, image 1 of 1
      • Remove the two 2.7mm Pentalobe #2 screws from the bottom of the phone.
      Ask FixBot
    3. Xiaomi Mi A2 Screen Replacement: step 3, image 1 of 3 Xiaomi Mi A2 Screen Replacement: step 3, image 2 of 3 Xiaomi Mi A2 Screen Replacement: step 3, image 3 of 3
      • Grab a suction cup tool and place it near the bottom of the phone.
      • Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
      • Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
      • Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
      • Flip the phone screen towards the bottom of the device and lay the screen facing down.
      • Note: The ribbon cable is in the middle of the panel, thus there is no need to be cautious about snagging a ribbon cable
      Ask FixBot
    4. Xiaomi Mi A2 Screen Replacement: step 4, image 1 of 2 Xiaomi Mi A2 Screen Replacement: step 4, image 2 of 2
      • When removing the ribbon cable and installing the new one take special care to not bend or fold the cable too much as this can cause damage to the cable itself.
      • To access the ribbon cable connectors we must remove the metal bracket.
      • Remove the three 2.4mm Philips #0 screws that hold the panel down.
      Ask FixBot
    5. Xiaomi Mi A2 Screen Replacement: step 5, image 1 of 3 Xiaomi Mi A2 Screen Replacement: step 5, image 2 of 3 Xiaomi Mi A2 Screen Replacement: step 5, image 3 of 3
      • Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
      • Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
      • After you remove the ribbon cable the panel should be free to remove and replace.
      Ask FixBot
18 other people completed this guide.
3 Guide Comments
Great guide, thanks!
The only thing, on step # 3 make sure you are removing both frame and display.
First time I by mistake removed display only, and saw quite a different internals (no battery, etc).
AI Mechanic - Reply Share
This worked great.
Only thing I would say in 2024 is be careful what replacement you buy. It was quite hard to find a replacement screen which was pre-mounted on a frame - most screens that are available on sale appeared to be just the glass and would be a bigger job than this guide covers to replace.
I eventually found a listing which had the frame too but only by scrutinising the product pictures - it didn't describe as having the plastic frame (nor did it cost any more).
Also, the replacement didn't have an ear speaker installed - I destroyed the existing one trying to swap it over... luckily the phone's owner doesn't use the ear speaker anyway.
DaveO - Reply Share
I have a mi a2 lite and i. Want. To do a screen replacement, is. Mi. A2 similar enough to mi. A2 lite so i could use this guide?
Vojtaa - Reply Share
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 93
All Time: 16,448
