Xiaomi Mi A2 Front Camera Replacement
    1. Xiaomi Mi A2 Front Camera Replacement, Screen: step 1, image 1 of 2 Xiaomi Mi A2 Front Camera Replacement, Screen: step 1, image 2 of 2
      • Turn off your phone before proceeding.
      • Remove SIM card tray from phone.
      • Touch something metallic to ensure you are electrostatic safe.
      Ask FixBot
    2. Xiaomi Mi A2 Front Camera Replacement: step 2, image 1 of 1
      • Remove the two 2.7mm Pentalobe #2 screws from the bottom of the phone.
      Ask FixBot
    3. Xiaomi Mi A2 Front Camera Replacement: step 3, image 1 of 3 Xiaomi Mi A2 Front Camera Replacement: step 3, image 2 of 3 Xiaomi Mi A2 Front Camera Replacement: step 3, image 3 of 3
      • Grab a suction cup tool and place it near the bottom of the phone.
      • Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
      • Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
      • Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
      • Flip the phone screen towards the bottom of the device and lay the screen facing down.
      • Note: The ribbon cable is in the middle of the panel, thus there is no need to be cautious about snagging a ribbon cable
      Ask FixBot
    4. Xiaomi Mi A2 Front Camera Replacement: step 4, image 1 of 2 Xiaomi Mi A2 Front Camera Replacement: step 4, image 2 of 2
      • When removing the ribbon cable and installing the new one take special care to not bend or fold the cable too much as this can cause damage to the cable itself.
      • To access the ribbon cable connectors we must remove the metal bracket.
      • Remove the three 2.4mm Philips #0 screws that hold the panel down.
      Ask FixBot
    5. Xiaomi Mi A2 Front Camera Replacement: step 5, image 1 of 3 Xiaomi Mi A2 Front Camera Replacement: step 5, image 2 of 3 Xiaomi Mi A2 Front Camera Replacement: step 5, image 3 of 3
      • Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
      • Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
      • After you remove the ribbon cable the panel should be free to remove and replace.
      Ask FixBot
    1. Xiaomi Mi A2 Front Camera Replacement, USB Port: step 6, image 1 of 2 Xiaomi Mi A2 Front Camera Replacement, USB Port: step 6, image 2 of 2
      • Remove the two 3.8mm Phillips #0 screws holding down the lower metal bracket.
      Ask FixBot
    2. Xiaomi Mi A2 Front Camera Replacement: step 7, image 1 of 2 Xiaomi Mi A2 Front Camera Replacement: step 7, image 2 of 2
      • Remove the loud speaker. There are three 2.4mm Phillips #0 screws you need to remove, and one (upper right) is underneath the Xiaomi water sticker.
      Ask FixBot
    3. Xiaomi Mi A2 Front Camera Replacement: step 8, image 1 of 2 Xiaomi Mi A2 Front Camera Replacement: step 8, image 2 of 2
      • Unplug the antenna wire with a spudger tool.
      • Remove another 2.4mm Phillips #0 screw near vibration motor.
      Ask FixBot
    4. Xiaomi Mi A2 Front Camera Replacement: step 9, image 1 of 2 Xiaomi Mi A2 Front Camera Replacement: step 9, image 2 of 2
      • The ribbon cable connector is located underneath the sub-board. To access the connector flip the board over towards the battery.
      • Use a spudger tool to remove the cable from the connector.
      • The USB Connector board can now be removed from the device and replaced.
      Ask FixBot
    1. Xiaomi Mi A2 Front Camera Replacement, Battery: step 10, image 1 of 3 Xiaomi Mi A2 Front Camera Replacement, Battery: step 10, image 2 of 3 Xiaomi Mi A2 Front Camera Replacement, Battery: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • On the bottom of the battery are two pull tabs. They are glued on to the battery similarly like a sticker.
      • To remove the battery pull these pull tabs downwards. WARNING: proceed with extreme caution, avoid bending or puncturing the battery.
      • You can use tweezers to lift the pull tabs from the battery. Pull downwards and the adhesive will slowly be removed from the battery.
      Ask FixBot
    2. Xiaomi Mi A2 Front Camera Replacement: step 11, image 1 of 1
      • Gently remove battery from its housing.
      • Component can now be replaced.
      Ask FixBot
    1. Xiaomi Mi A2 Front Camera Replacement, Front Camera: step 12, image 1 of 1
      • Using a plastic spudger, gently separate the front camera ribbon cable from the motherboard.
      Ask FixBot
    2. Xiaomi Mi A2 Front Camera Replacement: step 13, image 1 of 2 Xiaomi Mi A2 Front Camera Replacement: step 13, image 2 of 2
      Buy
      • Gently use the plastic tip tweezers to remove the front camera from the back housing of the phone.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 2,277
