Xiaomi Mi 9T Pro Screen Replacement
    1. Xiaomi Mi 9T Pro Screen Replacement, Heat the rear glass: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Xiaomi Mi 9T Pro Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Xiaomi Mi 9T Pro Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Xiaomi Mi 9T Pro Screen Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
      • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Xiaomi Mi 9T Pro Screen Replacement, Slice the adhesive: step 3, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Xiaomi Mi 9T Pro Screen Replacement, Slice the adhesive: step 4, image 1 of 3 Xiaomi Mi 9T Pro Screen Replacement, Slice the adhesive: step 4, image 2 of 3 Xiaomi Mi 9T Pro Screen Replacement, Slice the adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Mi 9T Pro Screen Replacement: step 5, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement: step 5, image 2 of 2
      • Insert a fourth opening pick underneath the top left corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Mi 9T Pro Screen Replacement: step 6, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
      • Do not try to remove the rear glass all the way yet. It might be adhered to the phone assembly because of the adhesive around the rear camera.
      Ask FixBot
    7. Xiaomi Mi 9T Pro Screen Replacement, Loosen the rear camera adhesive: step 7, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Loosen the rear camera adhesive: step 7, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Carefully try to separate the rear glass from the phone assembly. If you're successful you can ignore this step. In case the rear glass sticks to the rear camera adhesive, continue with this step.
      • Carefully insert a plastic or playing card at the right edge of the phone where the rear camera is located.
      • Use the plastic card to slice the adhesive along the rear camera frame.
      Ask FixBot
    8. Xiaomi Mi 9T Pro Screen Replacement, Remove the rear glass: step 8, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Remove the rear glass: step 8, image 2 of 2
      • Remove the rear glass.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Xiaomi Mi 9T Pro Screen Replacement, Unfasten the motherboard cover screws: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the twelve screws securing the motherboard cover:
      • Eleven 3.9 mm-long Phillips screws
      • One 2.3 mm-long Phillips screw
      Ask FixBot
    2. Xiaomi Mi 9T Pro Screen Replacement, Pry up the motherboard cover: step 10, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Pry up the motherboard cover: step 10, image 2 of 2
      • Insert the tip of an opening pick underneath the left edge of the motherboard cover.
      • Flip the opening pick sideways to pry up the motherboard cover.
      Ask FixBot
    3. Xiaomi Mi 9T Pro Screen Replacement, Remove the motherboard cover: step 11, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Remove the motherboard cover: step 11, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to remove the motherboard cover.
      Ask FixBot
    4. Xiaomi Mi 9T Pro Screen Replacement, Disconnect the battery cable: step 12, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Disconnect the battery cable: step 12, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    1. Xiaomi Mi 9T Pro Screen Replacement, Unfasten the loudspeaker assembly screws: step 13, image 1 of 1
      • Use a Phillips screwdriver to remove the eight 3.9 mm-long screws securing the loudspeaker assembly.
      Ask FixBot
    2. Xiaomi Mi 9T Pro Screen Replacement, Pry up the loudspeaker assembly: step 14, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Pry up the loudspeaker assembly: step 14, image 2 of 2
      • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the battery.
      • Use your opening pick to pry up the loudspeaker assembly.
      Ask FixBot
    3. Xiaomi Mi 9T Pro Screen Replacement, Remove the loudspeaker assembly: step 15, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Remove the loudspeaker assembly: step 15, image 2 of 2
      • Remove the loudspeaker assembly.
      • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      Ask FixBot
    1. Xiaomi Mi 9T Pro Screen Replacement, Peel off the connector sticker: step 16, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Peel off the connector sticker: step 16, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully peel the sticker off the interconnect cable.
      Ask FixBot
    2. Xiaomi Mi 9T Pro Screen Replacement, Disconnect the interconnect cable: step 17, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Disconnect the interconnect cable: step 17, image 2 of 2
      • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
      Ask FixBot
    3. Xiaomi Mi 9T Pro Screen Replacement, Free the display cable: step 18, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Free the display cable: step 18, image 2 of 2
      • The display cable is adhered onto the midframe by mild adhesive.
      • Carefully slide the tip of an opening pick underneath the display flex connector to separate it from the midframe.
      Ask FixBot
    4. Xiaomi Mi 9T Pro Screen Replacement, Loosen the display adhesive: step 19, image 1 of 1
      • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Ask FixBot
    5. Xiaomi Mi 9T Pro Screen Replacement, Insert an opening pick: step 20, image 1 of 3 Xiaomi Mi 9T Pro Screen Replacement, Insert an opening pick: step 20, image 2 of 3 Xiaomi Mi 9T Pro Screen Replacement, Insert an opening pick: step 20, image 3 of 3
      • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an opening pick into the gap between the midframe and the screen.
      • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
      Ask FixBot
    6. Xiaomi Mi 9T Pro Screen Replacement, Slice the adhesive: step 21, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement, Slice the adhesive: step 21, image 2 of 2
      • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
      Ask FixBot
    7. Xiaomi Mi 9T Pro Screen Replacement: step 22, image 1 of 3 Xiaomi Mi 9T Pro Screen Replacement: step 22, image 2 of 3 Xiaomi Mi 9T Pro Screen Replacement: step 22, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
      • Insert a third opening pick underneath the bottom left corner of the screen.
      • Slide the opening pick along the left edge of the screen to slice the adhesive.
      • Leave it in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    8. Xiaomi Mi 9T Pro Screen Replacement: step 23, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement: step 23, image 2 of 2
      • Insert a fourth opening pick at the top left corner of the screen.
      • Slide the opening pick along the top edge of the phone to slice the adhesive.
      Ask FixBot
    9. Xiaomi Mi 9T Pro Screen Replacement: step 24, image 1 of 2 Xiaomi Mi 9T Pro Screen Replacement: step 24, image 2 of 2
      • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
      • Do not try to remove the display all the way yet, the display cable is still threaded through the frame.
      Ask FixBot
    10. Xiaomi Mi 9T Pro Screen Replacement, Remove the screen: step 25, image 1 of 3 Xiaomi Mi 9T Pro Screen Replacement, Remove the screen: step 25, image 2 of 3 Xiaomi Mi 9T Pro Screen Replacement, Remove the screen: step 25, image 3 of 3
      • Thread the display flex cable through the gap in the midframe and remove the screen.
      • Compare your new replacement part to the original part—you may need to transfer remaining components from your old screen to your replacement part.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
20 other people completed this guide.
Dominik Schnabelrauch
263,543 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,578 Guides authored
7 Guide Comments
Wer wie ich vor der Herausforderung steht, ein Display inklusive Rahmen zu wechseln, dann wird man schnell feststellen, dass man den Akku ausbauen muss, welcher verklebt ist, was sehr gut funktioniert ist, das gesamte Telefon zu erhitzen, ich nutze dafür meinen 3d Drucker mit Platte auf 50°C.
Lasse das Handy dann einfach drauf und sobald der Akku warm ist (35-40° heißer würde ich definitiv nicht empfehlen - vielleicht noch 45) kann man den Akku ohne zerstörung, ohne großen Aufwand problemlos entfernen, dazu auf der rechten Seite die 3 Klebestreifen lösen und auf der linken Seite ebenfalls, rechts dann am mittleren Element ziehen da bei 1 und 2 der kleber befestigt ist, an 3 nur der Akku, die Kraft ist schwer zu beschreiben, aber wirklich nur ganz leicht ziehen.
Dann kann man den Akku durchaus nochmal benutzen. Wenn der Akku irgendwie beschädigt werden sollte, verbogen etc, auf keinen Fall weiternutzen, nur wenn der wirklich unbeschädigt ist.
Leon Buchholz - Reply Share
Where can i buy an original screen for this phone i literally just broke after 2+ years of having it, it fell face down while it still works perfectly the screen shows the crack of the damage still 100% usable but im heart broken about it, any links to amazon?
Nelson Morales - Reply Share
I have a good experience in this field and I need to work is there anyone to help me I am from Morocco
Khalilelharrak18@gmail.com
Khalil Elharrak - Reply Share
Hallo Dominik,
ich habe deine Anleitung befolgt und stehe nun vor einem nahezu perfekten Endergebnis. Nahezu perfekt, weil irgendwie nur meine obere Hälfte des Displays reagiert. Was könnte ich bei der Reparatur falsch gemacht haben? Einen Pin von einem Stecker zerstört? Oder ist das neue Display schon fehlerhaft bei mir angeliefert worden? Hast du da schon Erfahrungen gemacht? Grüße Mats
Peter Lustig - Reply Share
Could you make a tutorial for replacement of only the front glass?
danielssvieira1 - Reply Share
Past 24 Hours: 9
Past 7 Days: 65
Past 30 Days: 294
All Time: 31,010
