Xiaomi Mi 9 Front Camera Replacement
    1. Xiaomi Mi 9 Front Camera Replacement, Rear Glass: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Xiaomi Mi 9 Front Camera Replacement: step 2, image 1 of 3 Xiaomi Mi 9 Front Camera Replacement: step 2, image 2 of 3 Xiaomi Mi 9 Front Camera Replacement: step 2, image 3 of 3
      • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom right corner of the phone.
      Ask FixBot
    3. Xiaomi Mi 9 Front Camera Replacement: step 3, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Xiaomi Mi 9 Front Camera Replacement: step 4, image 1 of 3 Xiaomi Mi 9 Front Camera Replacement: step 4, image 2 of 3 Xiaomi Mi 9 Front Camera Replacement: step 4, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 9 to cut the adhesive.
      • Be aware of the rear cameras and only insert the tip of the opening pick. As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Mi 9 Front Camera Replacement: step 5, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement: step 5, image 2 of 2
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Mi 9 Front Camera Replacement: step 6, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right edge to cut the remaining adhesive.
      Ask FixBot
    7. Xiaomi Mi 9 Front Camera Replacement: step 7, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement: step 7, image 2 of 2
      • Carefully lift the rear glass and remove it.
      • Before installing new adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      Ask FixBot
    1. Xiaomi Mi 9 Front Camera Replacement, Motherboard Cover with Charging Coil: step 8, image 1 of 1
      • Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
      • There might be tamper proof sticker on some of the screws.
      Ask FixBot
    2. Xiaomi Mi 9 Front Camera Replacement: step 9, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement: step 9, image 2 of 2
      • Insert an opening pick at the top right corner of the motherboard cover.
      • Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
      Ask FixBot
    3. Xiaomi Mi 9 Front Camera Replacement: step 10, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement: step 10, image 2 of 2
      • Carefully remove the motherboard cover including the charging coil / NFC antenna.
      Ask FixBot
    1. Xiaomi Mi 9 Front Camera Replacement, Battery Disconnect: step 11, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement, Battery Disconnect: step 11, image 2 of 2
      • Use a spudger to pry up and disconnect the battery flex cable.
      Ask FixBot
    1. Xiaomi Mi 9 Front Camera Replacement, Front Facing Camera: step 12, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement, Front Facing Camera: step 12, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to pell the copper tape off the motherboard and fold it out of the way.
      Ask FixBot
    2. Xiaomi Mi 9 Front Camera Replacement: step 13, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement: step 13, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the flex cable of the front camera.
      Ask FixBot
    3. Xiaomi Mi 9 Front Camera Replacement: step 14, image 1 of 2 Xiaomi Mi 9 Front Camera Replacement: step 14, image 2 of 2
      • Use a pair of tweezers to lift the front camera out of its recess and remove it.
      Ask FixBot
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
2 other people completed this guide.
Dominik Schnabelrauch
265,880 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
4 Guide Comments
Can you suggest a replacement Front camera where I can purchase?
Manoj kumar - Reply Share
Muchísimas gracias por la guía. Pude Limpiar la cámara frontal sin ningún problema.
Naomi Díaz - Reply Share
Hello,
is there also a possibility to exchange a display on a Mi9?
Best Regards
Frank
Frank Michel - Reply Share
Hi Frank,
this AMOLED & Digitizer guide might be the one you’re looking for.
Dominik Schnabelrauch - Reply Share
Past 24 Hours: 9
Past 7 Days: 31
Past 30 Days: 97
All Time: 4,209
