Xiaomi Mi 4 Motherboard Replacement
    1. Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: step 1, image 1 of 3 Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: step 1, image 2 of 3 Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: step 1, image 3 of 3
      • Check to make sure that the device is powered off.
      • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
      • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
      Ask FixBot
    2. Xiaomi Mi 4 Motherboard Replacement: step 2, image 1 of 3 Xiaomi Mi 4 Motherboard Replacement: step 2, image 2 of 3 Xiaomi Mi 4 Motherboard Replacement: step 2, image 3 of 3
      Tool used on this step:
      Metal Spudger
      $2.99
      Buy
      • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
      • Using the second spudger, slowly work your way around the perimeter of the device
      • Listen for clicking sounds as you are prying the back cover away from the frame
      • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
      Ask FixBot
    3. Xiaomi Mi 4 Motherboard Replacement: step 3, image 1 of 3 Xiaomi Mi 4 Motherboard Replacement: step 3, image 2 of 3 Xiaomi Mi 4 Motherboard Replacement: step 3, image 3 of 3
      • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
      • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
      • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
      Ask FixBot
    1. Xiaomi Mi 4 Motherboard Replacement, Battery: step 4, image 1 of 3 Xiaomi Mi 4 Motherboard Replacement, Battery: step 4, image 2 of 3 Xiaomi Mi 4 Motherboard Replacement, Battery: step 4, image 3 of 3
      Buy
      • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
      • Proceed to gently remove the tape like connector from the battery until it is completely off.
      • Use tweezer to disconnect battery’s wire from the motherboard.
      Ask FixBot
    2. Xiaomi Mi 4 Motherboard Replacement: step 5, image 1 of 2 Xiaomi Mi 4 Motherboard Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to gently pry the battery out of its casing for removal.
      Ask FixBot
    1. Xiaomi Mi 4 Motherboard Replacement, Motherboard: step 6, image 1 of 1
      Buy
      • With the battery removed locate the left-hand cable connected to the motherboard. With the tweezers, firmly grasp the wires of the connector and gently disconnect the cable from the motherboard.
      • Find the other cable connecting the motherboard to the device at the top right-hand side of the phone, and carefully use the tweezers to remove that as well.
      Ask FixBot
    2. Xiaomi Mi 4 Motherboard Replacement: step 7, image 1 of 2 Xiaomi Mi 4 Motherboard Replacement: step 7, image 2 of 2
      • Wedge the plastic opening tool, between the motherboard and the inner region of the phone in the slot atop the motherboard.
      Ask FixBot
28 other people completed this guide.
William Pendeergraft
2,459 Reputation
4 Guides authored
USF Tampa, Team 15-6, Blackwell Fall 2015 Member of USF Tampa, Team 15-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G6
2 Members
48 Guides authored
9 Guide Comments
Ruined my motherboard to Xiaomi mi4c, do you know where can I buy?
Milos Milos - Reply Share
I have broken one of the cable connections on the motherboard ( top one in Step 6). Do you know where I can buy a new motherboard?
Ben Dungey - Reply Share
you can buy the motherboard on taobao.com
Dong Zhengyue - Reply Share
sim card reader is damaged. Do I need to have whole motherboard replaced
Shravan - Reply Share
sir i need MI4I motherboard unable to find elsewhere
Mobile # 09060907775
Thalanki Balaji - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 52
All Time: 38,366
