Xiaomi Mi 4 Battery Replacement
    1. Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: step 1, image 1 of 3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: step 1, image 2 of 3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: step 1, image 3 of 3
      • Check to make sure that the device is powered off.
      • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
      • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
      Ask FixBot
    2. Xiaomi Mi 4 Battery Replacement: step 2, image 1 of 3 Xiaomi Mi 4 Battery Replacement: step 2, image 2 of 3 Xiaomi Mi 4 Battery Replacement: step 2, image 3 of 3
      Tool used on this step:
      Metal Spudger
      $2.99
      Buy
      • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
      • Using the second spudger, slowly work your way around the perimeter of the device
      • Listen for clicking sounds as you are prying the back cover away from the frame
      • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
      Ask FixBot
    3. Xiaomi Mi 4 Battery Replacement: step 3, image 1 of 3 Xiaomi Mi 4 Battery Replacement: step 3, image 2 of 3 Xiaomi Mi 4 Battery Replacement: step 3, image 3 of 3
      • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
      • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
      • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
      Ask FixBot
    1. Xiaomi Mi 4 Battery Replacement, Battery: step 4, image 1 of 3 Xiaomi Mi 4 Battery Replacement, Battery: step 4, image 2 of 3 Xiaomi Mi 4 Battery Replacement, Battery: step 4, image 3 of 3
      Buy
      • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
      • Proceed to gently remove the tape like connector from the battery until it is completely off.
      • Use tweezer to disconnect battery’s wire from the motherboard.
      Ask FixBot
    2. Xiaomi Mi 4 Battery Replacement: step 5, image 1 of 2 Xiaomi Mi 4 Battery Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to gently pry the battery out of its casing for removal.
      Ask FixBot
49 other people completed this guide.
William Pendeergraft
2,459 Reputation
4 Guides authored
USF Tampa, Team 15-6, Blackwell Fall 2015 Member of USF Tampa, Team 15-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G6
2 Members
48 Guides authored
24 Guide Comments
Sir, I accidentally put a hole in battery while removing. Will this create a problem/explosion..
Apawilo Zawk - Reply Share
Hey Apawilo. A punctured battery has potential to be very dangerous (Fire, harmful chemicals, etc), so please make sure to dispose of it at the nearest e-waste recycling site.
Geoff Wacker - Reply Share
sir i am charging my phone but its percentage is not increasing ....this is a battery problem
adishsaggar123 - Reply Share
im having the similar problem, when charging power increase slower and the consumption is faster than usual. please advice. thanks
Zeff Soo - Reply Share
Hi..my xiaomi 4 cant be started.. after fully charged, it went blank n cant be restarted.. few days back, it was on n of for multiple time for several minutes...
Ezrat sam - Reply Share
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 163
All Time: 151,126
